Havn't posted anything in a while cause I had an off after I was hit by a car last August. The TDM is all repaired and 100% back on the road, One of the things I had to replace was the clutch lever, I bought one from Ebay but when it arrived it did not have the small paddle at the back that presses a small switch every time the clutch lever is pulled. Has anyone any idea what the little switch does, because the bike works grand with new lever????????????????????????????
Clutch Lever
Posted 17 April 2014 - 10:51 am
Posted 17 April 2014 - 12:01 pm
The switch de-activates a safety circuit.
If still with an original and correct set up; it should allow starter to operate when engine in gear with clutch pulled in.
Many have been shorted out to suit the requirements of an experienced rider.
Edit for xtra info;
Link to downloadable manual=worth a read.
http://www.google.co...XRuAk0qxNNlOpdA
Edited by Wildbill, 17 April 2014 - 12:16 pm.
Posted 17 April 2014 - 12:50 pm
Thanks, the bike works grand so i'll leave it as it is.
Posted 27 April 2014 - 02:00 am
Did you buy a yamaha lever and if so which one? Mine works but is worn out.
