Booster Plug Ecu Tweak
Posted 16 December 2016 - 07:44 pm
So now I'm tempted. If I can find an easy (no I don't want to feck about with airbox hacking and buggering around with other iffy solutions), once and for all fix for the on/off stutter at low revs, I might stop getting tempted to buy another bike.
https://youtu.be/UdkSSmpyanA
Gorn
Posted 16 December 2016 - 08:56 pm
I soldered a small value resistor (think it was 300 Ohms) in series with the temperature sensor.
The Boosterplug website section about how it works explains why simply adding a resistor is less than ideal. Well all i can say is that for the temperature range of operation in which I usually use my bike it doesn't work too badly at all !
http://www.boosterpl...hop/cms-21.html
The jerkiness of the TDM has several causes and if they all conspire in the same direction at the same time it can be a bit uncomfortable, but there is , I believe, sections of software code in the ECU which cannot be changed and which will always induce some throttle lag and little bit of hunting at lower revs.
My bike rides very differently to when I got it. As well as the resistor I have opened the airbox and advanced the timing by 4 degrees, which really make the bike a lot more pokey and fun....total cost has been less than £10.
Posted 16 December 2016 - 09:27 pm
Gorn
Posted 16 December 2016 - 09:55 pm
It is steep....If you can get one of the cheaper 'resistor only' versions it would give you an idea of if that is the correct engine sensor to tackle, or not.
I think for 200 -250 Euros you can get a full ECU remap and a lot of the fueling and timing parameters will be changed away from the exceptionally frugal setup they're currently tuned to.
I think the timing control is quite rough (based on how much better the bike rides with advanced timing) and in the back of my mind on a list of things to do is a programmable electronic timing adjuster idea which could make it a very easy mod
Posted 16 December 2016 - 10:17 pm
Gorn
Posted 16 December 2016 - 10:24 pm
I went down that path, I bought a secondhand ECU and already had the programming interface, so by using that guy's software i was able to read my ECU maps and tables and even sent them to him for checking (to make sure my hardware worked correctly). The last bit of the puzzle after modifying the maps is to load them back into the ECU, and for that he wants a couple of hundred dollars for a licence which unlocks the uploading side of his software....it's his playground so he can call the shots. One of the ROMs he has listed on that page came from my bike too !
I believe he has been involved with the Greek company Samios Motorsport who will do a full remap for 250 Euro. I keep meaning to try it, but it's a lot of cash....having said that it's cheaper than some power commanders, and unlike power commanders he modifies the timing curves as well as the fueling maps
Edited by fixitsan, 16 December 2016 - 10:25 pm.
