Posted 29 November 2019 - 05:20 pm
Just made this front wheel spacer in A4 stainless for the dablik Mk1 rebuild job. It was a very satisfying afternoon. The new playroom helped.
[attachment=12698:IMG_20191129_161008.jpg]
Centre drilling in collet chuck
[attachment=12699:IMG_20191129_162220.jpg]
Reaming to 17.00mm
[attachment=12700:IMG_20191129_163358.jpg]
On expanding mandrel to turn outside down to 28.00mm
[attachment=12701:IMG_20191129_165324.jpg]
Finished part.
[attachment=12702:IMG_20191129_165638.jpg]
