Engine Sound
46 replies to this topic
#1 erank
erank
  • 55 posts
Posted 03 January 2016 - 06:32 pm
Hello good folks, and happy 2016 :good:
I attached a short sound clip of my motor at idle, by the sound does it sounds like i got any issues (worn timing, knocking crank etc..)
Eran
#2 Studley Ramrod
  • 19,214 posts
Posted 03 January 2016 - 07:11 pm
Happy New Year. :)
Sounds like you've got the microphone resting on top of the engine, difficult to tell what the noise is or where it's coming from.
#3 celticbiker
celticbiker
  • 1,726 posts
Posted 04 January 2016 - 07:10 am
Sounds OK to me.
Niners tend to be a bit noisy on the top end due to the air injection valves.
Where are you based? Maybe someone could pop along and you could make a comparison.
#4 erank
erank
  • 55 posts
Posted 04 January 2016 - 01:07 pm
Sounds OK to me.
That's fine if someone fancy's a trip to the Holy land ;-)
#5 celticbiker
celticbiker
  • 1,726 posts
Posted 04 January 2016 - 01:44 pm
A bit far for a weekend away but if I can get a week off you never know.
How far is it from blighty, do you think?
#6 Rallyist
  • 3,253 posts
Posted 04 January 2016 - 03:45 pm
About 3750 miles and a couple of war zones :huh:
#7 pavel79
pavel79
  • 85 posts
Posted 12 September 2018 - 11:51 am
Hello everybody!
At first - sorry for my bad english :-(
I have TDM 900 ' 03, 56000 km run.
Now my engine sounds like this https://www.youtube....h?v=mbQ_vqa0R4M
Last winter I checked and adjust valve clearense, replace camchain tansioner and now I have this sound.
What is knocking noise from cilinder head?
May be camchain? When I checked valves camsprockets marks did not match 1/2 tooth.
Thanks for your advice :-)
#8 TDM4ever
TDM4ever
  • 302 posts
Posted 12 September 2018 - 01:30 pm
Can't really hear anything unusual? Maybe a little valve noise?
#9 pavel79
pavel79
  • 85 posts
Posted 12 September 2018 - 01:50 pm
Maybe valve, but I adjusted valves 4000 км ago.
Obviously I have to check it again.
#10 JMC
JMC
  • 257 posts
Posted 12 September 2018 - 01:54 pm
That ticking sounds like there is a little cam chain rattle, I had this recently on another bike best to check it right away
Hunter S. Thompson.
#11 pavel79
pavel79
  • 85 posts
Posted 12 September 2018 - 02:20 pm
Do you mean that the camchain has little stretched?
#12 dandywarhol
Posted 12 September 2018 - 03:13 pm
Both sound normal to my ol' ears
#13 drewpy
  • 1,758 posts
Posted 12 September 2018 - 03:31 pm
if i was being picky, valve noise, but nothing immediate needs doing
#14 fixitsan
  • 4,676 posts
Posted 12 September 2018 - 04:40 pm
Nooo ! Yorkshire isn't THAT far away :)
#15 JMC
JMC
  • 257 posts
Posted 12 September 2018 - 05:56 pm
It's only a tiny rattle and would doubt you need to be alarmed but as said it could be either valves or cam chain/tensioner but no harm checking both if your goin in there
Hunter S. Thompson.
#16 pavel79
pavel79
  • 85 posts
Posted 12 September 2018 - 06:47 pm
Thanks guys!
I have a greate desire to check it immediately but the weather is fine now in Belarus and I want ride ride ride :-)  Our winter is too long :-(
Unfortunatly in winter in my garage 5-7 degrees of heat. Perhaps this was the reason for the incorrect adjustment of the valves (it is not room tempreture).
Moto shims is small and may be very tamperature sensative.
#17 fixitsan
  • 4,676 posts
Posted 12 September 2018 - 08:11 pm
Not sure if yo0u already checked, but the early TDM900 had a replacement cam chain tensioner issued, because of failures in the early type. If you google tdm 900 cam chain tensioner you will find plenty opf info. The later type can be identified because it's base/flange is a little bit thicker than the early one. It should have been changed via a recall (from what i understand) but still worth checking
#18 pavel79
pavel79
  • 85 posts
Posted 12 September 2018 - 08:32 pm
I installed new type tensioner 4000 km ago.
#19 Hombre
Hombre
  • 448 posts
Posted 12 September 2018 - 09:32 pm
http://www.tdm-yamah...ex.php?page=TEN
#20 fixitsan
  • 4,676 posts
Posted 12 September 2018 - 10:06 pm
Nothing to worry about :)
