Edited by Coopz, 15 November 2022 - 10:49 pm.
Tdm 900 Expensive Service Quote?
Posted 15 November 2022 - 10:45 pm
Posted 16 November 2022 - 10:27 am
Edited by leehenty, 17 November 2022 - 12:08 pm.
Posted 16 November 2022 - 11:00 am
Quoted dollars so assume you're outside the UK. You could always do the rest of the service yourself to keep the cost down. Maybe even measure the clearances to if they need shims. If not confident enough yourself and no friends to help then you'll have to get the Card out.
As Lee says the valve check is the expensive bit.
Posted 21 November 2022 - 09:52 am
Good point about the checking clearances being easier than shim swapping.
You never know, you might not even need to swap any shims.
You need to remove the rocker cover, which involves removing the water pipe from the top of the head, if it isn't seized in place then the job is simple enough
Posted 21 November 2022 - 10:11 am
