Patoota Help Required
Posted 21 June 2010 - 07:07 pm
Have avast virus scanner. Think it runs automatically but the pc flashed some message too quick to read. So i ran the quick scan on c and d drives-
It said it found a virus and recommended put in vault and rename. Was a .sys file. Pc worked fine after. Turned off, tried to turn bacon this eve and it wont get to windows ...think i did a boo boo.
Oubt i can do to get pc workin?
Posted 21 June 2010 - 07:41 pm
Posted 21 June 2010 - 07:43 pm
Posted 21 June 2010 - 08:02 pm
Posted 21 June 2010 - 08:30 pm
#6 Guest_Paddy900_*
Posted 21 June 2010 - 08:56 pm
Have you changed the boot order?
Posted 21 June 2010 - 09:41 pm
http://distrowatch.com/
and download Mint and PClinuxOS (right hand side listing).
Mint uses the Gnome desktop, PClinuxOS uses the KDE desktop, both run off a live Cd so you can try them without actually putting anything on hard disk.
You can run Windows as well, (a dual Boot) on a separate partition. Unless you do on-line gaming you can then avoid Windows for the net and stay safe from nuisance virus problems.
I have run such a set-up for the last six years, never go near the net on Windows; works for me.
J.
I started ditching the hd's eventually as well.
Posted 21 June 2010 - 09:54 pm
Sounds like you need to get pci.sys (system file) back in.
Find some geek help and go into MSDOS and move that file back to it's original location.
Posted 22 June 2010 - 12:34 am
It was on XP.
Aint done oubt to boot order, do i need to? Trying to shove in disc was when i ran out of patoota talent.
Posted 22 June 2010 - 03:35 am
Sorry cant be more helpful than that other than to say i agree with bout using Linux, never had an online problem using it.
Posted 22 June 2010 - 05:59 am
I'll see if I can send you the file off my working and virus tested XP machine..... just copy it to the right spot and reboot, should work (I think! )
PM sent....
Edited by TimH, 22 June 2010 - 06:07 am.
Posted 22 June 2010 - 08:06 am
After typing in the whole Stop: 0x0000007E blah blah thing in google this morning it refreshed my memory that I got this thing before because I didnt have SP2 slipstreamed to the disk or summat. Tony sended me a disc...but maybe I shoved in the wrong one or summat.
Will try and find a slipstreamed disc or whatever and give it another go. Do I need to change the boot order loike what paddy mentioned?
Cheers for the help.
Posted 22 June 2010 - 09:24 am
if you have a SATA hard drive you cant use a windows XP CD without SP2 on it
Posted 22 June 2010 - 09:54 am
So if I get the slipstreamed disc thingy then I might be able to get back to windows? What do I need to do if/when I get back in?
Cheers.
#16
Posted 22 June 2010 - 09:59 am
#17
Posted 22 June 2010 - 10:05 am
Also you can install UBUNTU inside Windows and uninstall it without problems, but of course you need a running Windows OS.....
Bit drastic and non Linux bods don't like the sound of it but it's worth a try. I only keep Windows running as STEAM doesn't run on Linux sob.....
#18
Posted 22 June 2010 - 10:45 am
#19
Posted 22 June 2010 - 11:08 am
#20
Posted 22 June 2010 - 12:49 pm
Interesting....... may have to investigate this route
