What Are These
10 replies to this topic
#1 Jr5240559
Jr5240559
  • 14 posts
Posted 04 December 2019 - 02:03 pm
Hi bought bike Saturday, it came with a givi rack and plate, my question is do I need to mount the rack to the bike to support the top box, reason I ask is that on most of the pics of bikes I see the top box plate is mounted on top of the rear grab handles? Is this safe. My second question is that on my bike theres a steel bar thats connected to just under the rear light that runs to the rear heel guard, anyone know what it is, or what its for? Thanks for taking the time to read, Im new and its my first post
#2 catsbum
Posted 04 December 2019 - 04:03 pm
Very safe on the grab handles. I'll pop out later and do some pics for you
The long steel bar is to support the top rack plate but I think it's a different set-up to the grab handle mount
Cats
#3 Jr5240559
Jr5240559
  • 14 posts
Posted 04 December 2019 - 04:09 pm
Hi thanks for reply, have some pics of bike will try to upload them to give you a better idea of what Im talking about.👍
#4 catsbum
Posted 04 December 2019 - 04:18 pm
Just line up the plate to the existing bolts. Ignore strapping, that secures my tailpack
And just not to confuse things, ignore the crossed out bolts, they hold the indicators.
Cats
#5 Jr5240559
Jr5240559
  • 14 posts
Posted 04 December 2019 - 05:14 pm
Hi looking at your pics it seems that the plate is only attached by 2 bolt? Take it thats so, and take it its safe, if you look at pics of my bike you will see the bars that are on either side of bike that go from just under the indicators, to tha rear foot peg, what are they for? Thanks againAttached File  EB687B22-4130-42BC-845B-C8257B49DBD2.jpeg   152.29KB   0 downloadsAttached File  47BEE3F2-A9ED-48AE-9664-424BBCCED323.jpeg   152.29KB   0 downloads
#6 steve27bha
  • 784 posts
Posted 05 December 2019 - 01:55 am
The bars are made by Givi and support the rear of the subframe when there is a load on the rack / a topbox. My bike has these too and others have reported failures when using a topbox but no diagonals, so leave them on.
My Givi plate is bolted to the Yamaha grabrail but in a different way to that shown by Catsbum above, using the W-shaped plates Givi sometimes supplies.
If you do a Search using my handle and appropriate other key words you should find an old posting by me with pix and description.
ADD This thread discussing breakages includes my post #3:- http://www.carpe-tdm...=35274&p=357817
IIRC the top of the grabrail is convex and so the plate needs support under any bolts going into the edge of the rail or the plate will be flexed / bent so the box not fit correctly and the lock will be stressed.
ADD 5/12/19  This post #3 shows the mounting details:- http://www.carpe-tdm...=34995&p=354271
Later post #12 adds details.
Edited by steve27bha, 05 December 2019 - 01:19 pm.
#7 Rallyist
  • 3,253 posts
Posted 05 December 2019 - 08:33 am
Mine has those support rails but also the Givi rack fitted
Edited by Rallyist, 05 December 2019 - 08:34 am.
#8 Jr5240559
Jr5240559
  • 14 posts
Posted 05 December 2019 - 01:39 pm
Hi all, would like to say thanks to all the people that have took the time to answer my questions. Have had lots of bikes and joined lots of forums over the years, but must commend this one as the best so far. Keep up the good work and Ive no doubt that Ill be looking and hopefully contributing to your website. Thanks again 👍
#9 Snowbird
  • 1,357 posts
Posted 05 December 2019 - 01:52 pm
It's one of the very few that I've actually bothered paying into a membership of, might even be the first apart from the boaty one I ran myself for a few years. And no annoying ads!!! :good:
#10 leehenty
  • 5,088 posts
Posted 05 December 2019 - 08:38 pm
I have a wingrack, but still left those diagonals on from the previous set up. it supports the alloy subframe.
#11 Jr5240559
Jr5240559
  • 14 posts
Posted 07 December 2019 - 09:56 am
Thanks again all that replied.👍
