Rattling From The Right Side Of The Engine When Throttling Off.
68 replies to this topic
#1 SeizedBalt
SeizedBalt
  • 246 posts
Posted 13 May 2020 - 09:55 am
Well, trying hard not to get despondent after having shelled out a shed load on my new bike already but I just heard a rattling on the right hand side of the engine. Id only been on the road about 5-10min to my first stop.
Could be camchain slap.
Checked the engine oil and the level is good.
Is this a sign of the oft-mentioned cam tensioner issue?
If so, what does it mean for now (Ie before I can address it)?
And if not, any suggestions as to the cause?
On a personal note, I dont do quirks on my bikes. They trample my confidence in it and thus trample my enjoyment of riding it so the sooner I can make this noise go away, the better!
Cheers.
Edited by SeizedBalt, 13 May 2020 - 09:55 am.
#2 wicklamulla
Posted 13 May 2020 - 11:22 am
is it the modified cam tensioner that is fitted  i wonder? some people manage to make the tensioner ratchet on a click by manually assisting it.
#3 SeizedBalt
SeizedBalt
  • 246 posts
Posted 13 May 2020 - 12:28 pm
No idea. Externally I looks like any other based on the pictures Ive seen.
But Im about to hand it over for the clearances to be checked and my concern is that a faulty tensioner (beyond risks to the timing) may also make the work Ill be paying for pointless.
I've checked it and I'm pretty sure it's the old one.
Edited by SeizedBalt, 13 May 2020 - 04:57 pm.
#4 dapleb
  • 18,118 posts
Posted 13 May 2020 - 01:40 pm
Difficult to know problemo without hearing it. Is this a new noise or one you have just noticed?
I don't do 9ers but I think that they centre punched by the vin plate or summat to denote if recall had been done. There will be info here about which vin numbers were involved in recall.
I think the 9er has the spiral/spring design of tensioner so dont think there is any ratcheting up to the next click to be done....they changed the simple and effective 850 design as it was errr simple and effective and they were bored of that kind of thing!!!!!!
#5 Bjørge
  • 1,792 posts
Posted 13 May 2020 - 01:45 pm
It may have been changed outside warranty... I did on my 9er.
Quite easy to just remove it and check, though ? Just need to be "reset" or whatever you'd say. Check JBX site for how to position crank afore loosening it. I followed these instructions and had no issue with skipping teeth on camchain sprockets just removing the tensioner.
#6 Rallyist
  • 3,253 posts
Posted 13 May 2020 - 02:39 pm
The difference can be checked easily whether you have the modified tensioner or not
TENS_12.jpgAttached File  TENS_12.jpg   99.35KB   1 downloads
Edited by Rallyist, 13 May 2020 - 07:02 pm.
#7 Studley Ramrod
  • 19,214 posts
Posted 13 May 2020 - 06:42 pm
Good find Graham. :good:
#8 dapleb
  • 18,118 posts
Posted 13 May 2020 - 06:50 pm
What ya seein SR? I just get an "access denied" page.
#9 Studley Ramrod
  • 19,214 posts
Posted 13 May 2020 - 06:53 pm
Weird, first time I looked at Grahams post all I got was part of the the image txt, looked again after a minute or 2 and the image is there.  Wondering if JBX's site is having a hissy ?
Can you see the image below ?
#10 dapleb
  • 18,118 posts
Posted 13 May 2020 - 06:58 pm
No SR still no worky. Tried opening in new tab but still no joy.
#11 Studley Ramrod
  • 19,214 posts
Posted 13 May 2020 - 07:04 pm
Here ya go Daps.
Attached File  Tens.jpg   230.49KB   3 downloads
#12 dapleb
  • 18,118 posts
Posted 13 May 2020 - 07:10 pm
That learnt it SR, ta. So basically a bigger stronger spring to push the silly spiral harder!
#13 SeizedBalt
SeizedBalt
  • 246 posts
Posted 13 May 2020 - 07:14 pm
Mine is the older version: 38mm.
I'm almost certain as I asked the bike shop man today to use calipers to measure and he came back saying 37mm, but then he was bent over and an odd angle. Hence probably 38mm versions.
#14 Studley Ramrod
  • 19,214 posts
Posted 13 May 2020 - 07:23 pm
Had to download image then post up myself.
Anyhoos, new wan also has a longer barrel so pushrod is less flippyfloppy when fully extended.
#15 rlittlefellow
rlittlefellow
  • 14 posts
Posted 13 May 2020 - 07:45 pm
If your changing the CCT dont pay the UK prices, if that's where your based. I order mine from here 80 quid delivered!
https://www.megazip....in-5PS122101000
Edited by rlittlefellow, 13 May 2020 - 07:45 pm.
#16 drewpy
  • 1,758 posts
Posted 13 May 2020 - 08:45 pm
last time I ordered from japan it cost an extra £14- £7 for import and £7 to post office.
#17 dandywarhol
Posted 14 May 2020 - 05:14 pm
Modified ones are a different shade of engine paint colour
#18 SeizedBalt
SeizedBalt
  • 246 posts
Posted 14 May 2020 - 06:39 pm
I went to see the dealer today. Didnt have the bike but I described the symptoms and he plummed for the tensioner as the likely culprit.
He said to bring it in for them to have a listen but so far so good. Ill petition for the upgrade tensioner but if its the old type for free of the new one out of my pocket, Ill settle for the old one.
Once done Ill still get the cam chain and valve done.
Then I can focus on the forks and head race bearings. Then and only then, I can relax...
#19 wicklamulla
Posted 14 May 2020 - 11:00 pm
yer mad in my humble opinion!  i'd simply buy the modified tensioner and ask the dealer if he'll contribute towards it or give ya some free enjun oil in lieu of a donation. I remember a couple of TDM 900's going BANG cos the owners didn't heed the advice to replace the old style tensioner for the new style. Anudder TDM rider and pillion rode from UK to Pakistan (i think it was) and his timing jumped about 2 teeth and the bike ran rough as a badgers nadger till he got it fixed,  luckily there was no damage.  Also check the TPS has been changed too.
#20 SeizedBalt
SeizedBalt
  • 246 posts
Posted 15 May 2020 - 04:14 am
Believe me Im gonna push for the new version.
But in any case I get your point and Im taking it seriously.
And what is the TPS?
Dunno that one.
