Anyone Fitted Paddock Stand Bobbins
Posted 01 October 2016 - 04:19 pm
Has anybody tried this method? If not can you suggest something better. I want to use a paddock stand as I have just ruptured my Achilles putting my Tiger on the centre stand and don't want to do it again on my TDM 850
Posted 01 October 2016 - 05:00 pm
Posted 01 October 2016 - 05:21 pm
Abba stand is the way to go, should be 10% off on the forum, bike behaves like it's on a pendulum, easy to lift and 2 axle stands under the crash bars to get the front up..
Posted 01 October 2016 - 05:41 pm
On my 850 I use the type of paddock stand with flat supports that lift under the swing arm, it works fine. You can then jack the engine (carefully!) to lift the front end.
If you wanted to fit bobbins on an 850 I'd drill right through, clearance for an 8mm bolt, then make a chunky spacer to allow the bobbin to be fitted & tightened up without crushing the swing arm. You'll need to strip off the wheel and adjusters to fit the spacer but it should be solid.
Posted 02 October 2016 - 06:41 am
The 9er has points already in place - not the same on the 850?
