Mk1 Quieter Slip On Silencers?
35 replies to this topic
#1 Grendel
Grendel
  • 227 posts
Posted 05 December 2017 - 06:59 pm
My bike currently has this silencer fitted to SS down pipes:
http://www.delkevic....0&search=pr1828
To be honest its too loud. There wasn't much difference when I removed it and run the bike without it on just down pipes.
I have a feeling the baffels have been removed.
So what other Quieter slip on Silencers are out there that dont cost a fortune.
Edited by Grendel, 05 December 2017 - 07:33 pm.
#2 fixitsan
  • 4,668 posts
Posted 05 December 2017 - 07:55 pm
Measure the internal diameter of the exit pipe, and buy an appropriate 'db killer'. You might have to drill a 3mm hole under the exit piece of the exhaust to fit the retaining screw, but it must be cheaper than a new can.
You will need an angled one, but it will take a lot of the energy out of the sound, probably leave you with a nice rumble instead EG http://www.ebay.co.u...SMAAOSwz~VZoPxO
Use 'db killer' as a search clue on ebay and you'll find loads of them
It goes without saying that you should only get a stainless one or it might not last 2 seasons
Edited by fixitsan, 05 December 2017 - 07:57 pm.
#3 Grendel
Grendel
  • 227 posts
Posted 05 December 2017 - 08:04 pm
Thanks for that.
I think it has something bolted in end of silencer?
I'll take it out and have a proper look tomorrow.
Hopefully its just been cut short or somthing since don't fancy the idea to drilling rivets out to re-pack it.
Delkvic do 2 that should fit one being an oversize baffel?
http://www.delkevic....roduct_id=23684
http://www.delkevic....dels&SKU=PR2737
Edited by Grendel, 05 December 2017 - 08:14 pm.
#4 madmopedracer
madmopedracer
  • 473 posts
Posted 05 December 2017 - 08:08 pm
could do a swap for some std enterprise exhausts
#5 fixitsan
  • 4,668 posts
Posted 05 December 2017 - 08:09 pm
Thanks for that.
Maybe it already has one then. You could wrap it with some exhaust wadding and wire mesh, that takes some of the ping out of them
#6 g650xtdm
g650xtdm
  • 295 posts
Posted 06 December 2017 - 01:09 am
I have that same exhaust.  It is louder than stock, but not incredibly so.  I don't recall it having an insert.  Maybe it needs to be repacked or maybe somebody gutted it?
In hindsight, I wish I had got the longer one as it is probably a little quieter.  But I don't find it so loud it annoys anybody.  I would guess only 10-20 percent louder than stock.
#7 Grendel
Grendel
  • 227 posts
Posted 06 December 2017 - 09:43 am
Hmm Interesting it appears to have the this fitted and the inner perforated tube seems intact?
But if i take it out it stays the same volume just a bit more raspy?
Edited by Grendel, 06 December 2017 - 10:47 am.
#8 Grendel
Grendel
  • 227 posts
Posted 06 December 2017 - 10:48 am
I have decided to buy the longer one to see if it makes any difference. Since £25 is still cheaper than new silencer.
Edited by Grendel, 06 December 2017 - 10:49 am.
#9 Swarf
Swarf
  • 314 posts
Posted 06 December 2017 - 12:50 pm
Is the plate on the end of the baffle intact?
#10 Grendel
Grendel
  • 227 posts
Posted 06 December 2017 - 12:52 pm
Everything seems to be as it should?
Perhaps the packing has disintegrated since doesn’t look like it’s been taken apart?
#11 Swarf
Swarf
  • 314 posts
Posted 06 December 2017 - 03:35 pm
Possibly. I had one of those on a Triumph Sprint and the baffle made quite a difference on it.
I may be selling a mint condition stock silencer soon if it's of any interest.
#12 g650xtdm
g650xtdm
  • 295 posts
Posted 06 December 2017 - 09:58 pm
Where did you find the longer insert?
#13 TDrummer
TDrummer
  • 192 posts
Posted 07 December 2017 - 05:26 pm
I bought a muffler off an 06 Kawasaki ZX1400.
Sounds amazing and no repacking needed.
I think I paid $45. (about 30 pounds?).
#14 Grendel
Grendel
  • 227 posts
Posted 08 December 2017 - 09:11 am
g650xtdm:
#15 g650xtdm
g650xtdm
  • 295 posts
Posted 08 December 2017 - 11:32 pm
Thanks!  I will give it a try too.  I like quiet.
#16 g650xtdm
g650xtdm
  • 295 posts
Posted 15 December 2017 - 01:24 am
I got that quieter insert today and installed.  It seems a bit quieter, but I am sort of guessing since I am normally wear ear plugs and forgot to test them, one after another.  But I will say it sounds a lot better with the quieter baffle in - much deeper in addition to what seems like a slightly lower volume.  Thank you for the suggestion.
#17 Grendel
Grendel
  • 227 posts
Posted 15 December 2017 - 04:00 pm
Fitted mine today as well. Seems deeper now and only slightly less noisy.
#18 paultdm850
paultdm850
  • 114 posts
Posted 15 December 2017 - 07:18 pm
I've got the same one and I've had to repack it twice. Once the fine mesh burns out around the baffle tube it seems to burn through the packing quicker, especially with the baffle in. Although you'll know when the packing is mostly gone as it'll cook the rubber around the hanging bracket and it'll cost you a tenner to replace! The 350mm does look good though.
#19 fixitsan
  • 4,668 posts
Posted 15 December 2017 - 07:27 pm
I successfully made an internal baffle for the 850 using perforated stainless tube, EG https://www.ebay.co.uk/itm/PERFORATED-STAINLESS-STEEL-PIPE-TUBE-EXHAUST-SILENCER-REPAIR-SECTION-32MM-76MM/131891666850?var=431574438064&hash=item1eb55b1fa2:m:mkaOdXos9mghbsxKKRrcTBw
Almost unburnable, might be able to make a sleeve to hold the wadding to the internal baffle pipe with it
#20 Grendel
Grendel
  • 227 posts
Posted 15 December 2017 - 07:40 pm
Hmm The rubber around the hanging bracket is rather melted.
