Hi All
I'm about to pick up a 2000 TDM850 and have no prior experience of these, are there any bits I need to look at and what are the common issues with these, I believe they got better after 1999.
Thanks for any good pointers.
Dave.
Posted 01 July 2019 - 08:18 am
Hi All
Dave.
Posted 01 July 2019 - 09:10 am
Hi and welcome Dave. Oil usage is prolly the main thing to keep an eye on. Some use a bit of oil, some use a lot, and some use too much. Check the oil level regularly until you can work out how much it uses.
Gearbox should be fine, it's generally the early mk1's that have 3rd gear issues. Check rear lower shock mount is greased up properly, they can and do sieze and will snap off if they do.
Posted 01 July 2019 - 11:44 am
welcome to the site
Posted 01 July 2019 - 12:55 pm
Any good tuning mods I should know about? It already has a delkevic exhaust system.
Posted 02 July 2019 - 01:55 pm
Hi All
Dave.
They got even better in 2002..
Welcome to the forum
Edited by TDM4ever, 02 July 2019 - 04:12 pm.
Posted 02 July 2019 - 02:35 pm
Greetings
Posted 02 July 2019 - 03:12 pm
Posted 02 July 2019 - 03:20 pm
Thanks for the welcome pepes.
Posted 07 July 2019 - 09:35 am
Hi, welcome!Any good tuning mods I should know about? It already has a delkevic exhaust system.
Posted 07 July 2019 - 10:23 am
That sounds interesting, may have to look into that one.
Now have my new toy in my posession and had a couple of runs and love it, totally different ride to my fazer thou but more soul.
However did the get the nickname tedium? A great b road blaster!
Posted 07 July 2019 - 04:52 pm
Goodman, thank god you like it eh, dont think the fazer's a stranger on here though, also well thought of, basically the same + 2
Posted 07 July 2019 - 06:41 pm
The fazer is a great bit of kit and goes like feck but it's almost too smooth hence the lack of soul comment, especially with the ivans jet kit in the carbs, anyone wanna buy a fazer thou?
It's meant to be good for 160mph but I only managed to get 158 out of it....... (alledgedly) (on a private road of course)(lieing twat)
Posted 08 July 2019 - 07:46 pm
Hi, welcome!
One I recently came across is the disconbection of two wires from the gearbox to the ecu, removing essentially a torque limit in 2nd and 3rd gear. Much smoother at low revs as well. Definite the best bang for buck tuning so far...
2010 TDM900A
1994 TDM850
Posted 08 July 2019 - 07:56 pm
You can take a look here:That sounds interesting. Could you give more info, or link to a post with details?
Edited by MipeTDM, 08 July 2019 - 07:58 pm.
Posted 17 July 2019 - 02:38 am
Hi All
Dave.
New here as well and looking at a 2002 TDM 900 as next project. This looks like a knowledgeable community.
Posted 17 July 2019 - 08:02 am
Greetings - lots of info & experience (many will also help for cake), freely available from the members
