Tdm 900 Snappy Response
37 replies to this topic
#1 ABurtchaell
ABurtchaell
  • 3 posts
Posted 10 September 2021 - 05:53 am
Does anyone know if you can get the injection mapping updated to give a smoother throttle response at lower speeds/revs?
I've tried a booster plug and (I think) it has helped a bit but I still find the low speed throttle response too snappy!
I really like my TDM 900 in all other respects but it does spoil what is a great bike and I wanted to know if this can be fixed?
Thanks for any advice you can give.
#2 fixitsan
  • 4,671 posts
Posted 10 September 2021 - 06:13 am
You can have a remap, if the ECU is one of a small number of variants which allow it.
I had mine done and it improved the ride.
I believe the snappy throttle was improved with a feature of the remap called 'fuel cut-off inhibit'
With most injection systems, when you release the throttle to decelerate the fuel supply is cut off hard and the engine decelerates quickly causing lots of engine braking.. With carbs instead of injection, a small amount of fuel is still going into the engine which reduces engine braking a little
I felt (personal opinion) that the extreme engine braking and rapid fuel cut-off contributes to some of the snatchyness, particularly noticeable when going around roundabouts or large turns where you're trying to balance the throttle, the fuel cut-off effect made it difficult to find the 'right amount of throttle' as it switched between it's two states.
I keep toying with the idea of making something which could be retrofit to a bike to defeat the cut-off just to smooth out the transitions between both states b ut there's a lot of other things I mean to get a round to doing but don't seem to have the time for too !
#3 dapleb
  • 18,114 posts
Posted 10 September 2021 - 06:31 am
Hello dare and welcome!!
Carbs?
#4 dandywarhol
Posted 10 September 2021 - 09:06 am
Carbs?
Not unless he's converted it from FI Badger - 2006. This could be a long thread....................
Edited by dandywarhol, 10 September 2021 - 09:06 am.
#5 dapleb
  • 18,114 posts
Posted 10 September 2021 - 12:17 pm
That's my point...carbs will git rid of his snatch.
#6 Favs
  • 4,394 posts
Posted 10 September 2021 - 01:57 pm
If there's some spare snatch................
#7 Snowbird
  • 1,354 posts
Posted 10 September 2021 - 05:22 pm
A 9er rider with a snatch? I take it he took the pink knickers thing a bit too far then?
#8 Gdogg
Gdogg
  • 1,163 posts
Posted 10 September 2021 - 09:41 pm
Trust you !! 🙄🤣
Edited by Gdogg, 10 September 2021 - 09:41 pm.
#9 fixitsan
  • 4,671 posts
Posted 11 September 2021 - 07:31 pm
:rotflmmfao:
#10 chrisr
  • 1,745 posts
Posted 11 September 2021 - 11:37 pm
Enough silliness! First things to check are the clutch lever play, the throttle cable tension and the chain adjustment, sometimes just getting these right can help.
#11 ABurtchaell
ABurtchaell
  • 3 posts
Posted 12 September 2021 - 09:45 am
Hi Fixitsan,
Can you tell me who you got to remap your ECU?
Mine is a 2006 version, so will need to see if mine can be done?
#12 fixitsan
  • 4,671 posts
Posted 12 September 2021 - 10:04 am
Hi Fixitsan,
Can you tell me who you got to remap your ECU?as a Greek company (I'm in the UK)
It was done by Samios Motorsport. They have a page on Facebook as well as their company website.
You will need to take a photo of the ECU product label and send it to them when requested, they then look it up in the big book of ECUs to see if it can be reprogrammed. It cost about £250.
I let a few other people test it on their bikes and the opinion is that it doesn't seem to make very much more power or torque, but the limiters for torque in lower gears are removed, fuel cut-off is disabled, A few other bits and pieces are changed such as the temperature at which the fan kicks in is lowered too.
It just feels all around more rideable and 'complete' everything works together a bit better, IMHO
I have changed back to the original ECU a couple of times for comparison, the bike doesn't feel quite as quick with the original ECU, and it doesn't feel anywhere near as smooth. The remap doesn't necessarily cause much of an increase in fuel consumption and ridden carefully it isn't particularly noticeable
Where do you live ? If you're in Scotland I'm in Livingston and can  let you try it on your bike if you like. Or this week I'm in Peterborough until Thursday so i could bring it with me if you're close by and try it for yourself , It's a 5 minute swap once the side panel is removed
Edited by fixitsan, 12 September 2021 - 10:07 am.
#13 chrisr
  • 1,745 posts
Posted 12 September 2021 - 02:24 pm
Not sure if the 06 has an immobiliser, when I tried fixitsans Ecu on my 2010 model it wouldnt start. And Samios couldnt remap my Ecu.
Edited by chrisr, 12 September 2021 - 02:25 pm.
#14 fixitsan
  • 4,671 posts
Posted 12 September 2021 - 04:30 pm
That's right, I forgot about us trying that out.
ABS is a deciding factor
#15 wicklamulla
Posted 12 September 2021 - 07:34 pm
Hi Chrisr,  does yer 900 have ABS?
#16 fixitsan
  • 4,671 posts
Posted 12 September 2021 - 07:48 pm
immobiliser/ECU is a deciding factor
#17 chrisr
  • 1,745 posts
Posted 13 September 2021 - 04:11 pm
No
#18 fixitsan
  • 4,671 posts
Posted 13 September 2021 - 06:31 pm
No
What about an immobiliser ?
#19 trevini
trevini
  • 1,777 posts
Posted 13 September 2021 - 07:47 pm
Immobiliser was standard fit across the board from 2004 my onwards Chris. To not have one it’d have to be a very old bike hanging around unsold.
2004 Galaxy Blue. Owned since 486 miles.Renthal 755 bars, Bagster tank cover, Oxford heated grips, DL650 hand guards, Double Bubble screen, Scorpion Rad guard, Gel pad insert, HLD undertray, Angry Badger tailtidy,  Michelin Road 5s, Givi E21s, E46 topbox, Ohlins shock and YSS cartridge emulators   Currently not fitted - PC3, Remus Revolutions.
#20 fixitsan
  • 4,671 posts
Posted 13 September 2021 - 10:28 pm
That's the 'kicker' as they say.
Mine is '04 reg but MY '02 so that's why it was probably easy to reprogram.
I think when I get the time I'ld like to make some sort of fuel-cut defeat device
