Hi, I'm new here, so don't be angry at me, if this topic already exists, after searching I couldn't find anything that this would fit under.
I have a 2004 TDM, with 65k KM (not 100% sure if its correct or not).
When i bought the bike a year ago, it ran fine (not super good, but OK enough to warrant me to buy it), but a few months later it started developing engine issues.
1st was tick, what lead to checking camchain tentioner and camchain. Chain was worn and the tentioner was the original version 1. Got new chain, new tentioner.
While swapping the chain, noticed that the exhaust cam was not moving freely without chain, took it out and saw that there was bearing damage and it was quite bad, intake cap had some wear, but not that bad.
Started looking for a new cylinder head + cams but didn't find anything for months. At some point a found used running 2003 TDM engine and bought that. Cylinder head looked gear, little wear, cams where great as well.
Swapped over the entire head, cams and put in the new chain + tentioner and did the valve clearances.
At some point, I noticed, when the bike is cold, on start it starts knocking, its not coming from the head or cylinder, but feels like gearbox or around there. It goes away after the engine warms or you give it some throttle.
Other than that, bike rides fine, all of the power is there, revs up to redline just fine. Low RPM is still twitchy, I have only pulled the wire out and it improved throttle a bit.
I have checked the cold start mechanism and its working fine, its not stuck. Thats one of the things I checked to make sure its not that.
I put a small video of the noise up on youtube, I recorded it with my phone, so the audio might not be super good, but it all should be heard.
Thanks for any comments and suggestions.
