2004 Tdm 900 Not Starting
24 replies to this topic
#21 Fenestrom
Fenestrom
  • 9 posts
Posted 09 November 2021 - 11:57 am
Lots on cams and timing in the knowledgebase have a read through, 9r in further pages but near as the same for 8fiddly...
Ps If you wanted to check the cam sensor for sure, i took out the crank sensor from behind the sprocket cover as a swap to test the cam sensor ( i believe it's actually a "get you home swap") bike ran rough as a pigs ear but proved a buggered cam sensor, perhaps worth checking, i did have help and your more clued up than i am, but perhaps it may help !!!
Many suggest that the cam sensor and the speedo sensor are the same but they do have a different profile although the same electrical characteristics. I did try using speedo senso as a try out but to no avail.
Have you done a compression check ?
I was going to then realised that the thread on my compression tester was too big. Doh
There is no Cloud, it's merely someone else's computer.
#22 Fenestrom
Fenestrom
  • 9 posts
Posted 15 March 2022 - 07:18 pm
UPDATE
Many thanks for the interest shown on this thread and my problem
It was valve based. Cam tensioner had failed in a big way and timing chain had jumped sprockets.
No valve damage though. 3 broken exhaust studs but should be sorted OK
Many thanks to all for consideration
#23 dablik
  • 10,757 posts
Posted 15 March 2022 - 07:22 pm
Good to hear, the sensors are different which is known, replacing the cam with the speed sensor is a get you home aid as such and not a direct replacement though, i swapped mine out years ago and the bike ran albeit a bit rough, but told me the cam sensor was foobar.
Looks like you got lucky with the tensior and no valve damage  :good:
#24 Studley Ramrod
  • 19,214 posts
Posted 16 March 2022 - 07:35 am
:good:
#25 Snowbird
  • 1,359 posts
Posted 16 March 2022 - 08:18 am
Nice one, give us an update when it fires into life.
