99,999.9 Moiles.......one Hundred...err No Wait Zero Moiles!
Posted 23 June 2022 - 07:49 pm
[attachment=14852:Screenshot_20220623-200407.png]
[attachment=14853:Screenshot_20220623-200417.png]
[attachment=14854:Screenshot_20220623-200424.png]
Posted 23 June 2022 - 10:28 pm
Woopwoop
Posted 23 June 2022 - 10:51 pm
ᕦʕ ᴥʔᕤ
Posted 23 June 2022 - 10:53 pm
Hardcore - well done. May you and her continue to prosper.
Posted 24 June 2022 - 07:16 am
How many of them have you done? And has the bike needed any major work in that time?
Posted 24 June 2022 - 08:00 am
The enjun seized and shoved a con rod through the sump liberally applying what oil was left to his back wheel and some plop to his pants!!!!
When we went to pick it up twev didn't know what was wrong with it....the big hole in the sump shoulda been a clue. He thought the back wheel was locked because enjun was seized so he was quite surprised when we snicked it out of gear and pushed it into the van....past the drag marks in the gravel he had made dragging it into the garage. ʘ‿ʘ
So I rebuilt one of the garden ornament enjuns and shoved it in there. Boike was already on approx 45,000 by that point. All other components checked and made mechanically excellent (not bothered how it looks). That took me a few years to get around to as I had a MK2 already and had clocked up 50,000+ on dat. So I'm also on 100,000 TDM moiles. There was no point in keeping both when MK1 finished and since the MK2 was in excellent mechanical AND aesthetic condition (no use to me for strapping onto ferries etc) the MK2 went.
So yes..it has needed a few bits...an enjun...ermm...other than that fuel pump (though orig still works). Farter solenoid (orig still works) Mulshion toobs....I have changed shock for mk2. Most udder bits are original but many rebuilt.
I have loads of bits that I rebuilt in 2012 and on...calipots, master cyl and brake lions, forks, etc but never got around to fitting plus some licky bits from dabbers boike and also a new garden ornament that I started rebuilding....but interested to know how far me rebuilt unit will go before needing work so no point in hurrying that..started about 10 years ago.
Posted 24 June 2022 - 08:12 am
Edited by leehenty, 24 June 2022 - 03:21 pm.
Posted 24 June 2022 - 08:16 am
Earnt a lille fettling coming soon. Noubt major just some of yer noice bits.
ᕦʕ ᴥʔᕤ
Very good, pop some of the bits on furra makeover, she'll be looking new
Posted 24 June 2022 - 08:51 am
Major milestone
Posted 24 June 2022 - 09:05 am
BTW...trigger's broom sprung to mind!!
Posted 24 June 2022 - 10:57 am
The last 10,000 moiles did take me 8 years......so oi won't be getting any letter fur the next lap.
Posted 24 June 2022 - 12:31 pm
well done PK, Yer missing a tang on that fairing! Did the 'slow build of the 3VD with TDM 900 pistons and barrels' ever come to completion?
Posted 24 June 2022 - 01:34 pm
All tangs present. Some switched to a red tang alternative (you can't upgrade from yellow). And a larger species of yellow tang fitted....just can't remember where. Edit: oh I see top left. Started with 1 tang....maybe it's time for a final tang there.
Posted 24 June 2022 - 01:40 pm
nice one, time for celebration cake
Posted 25 June 2022 - 10:30 am
Time to sell it, a Mk1 with 0 miles on the clock will be worth way more than one with 99,999 on the clock was!
#16
Posted 25 June 2022 - 04:57 pm
MoT cert. required
Posted 25 June 2022 - 09:08 pm
Good plan.
[attachment=14863:Screenshot_20220625-220642.png]
#18
Posted 27 June 2022 - 03:58 pm
I was gonna say Triggers Broom Congratulations Daps
#19
Posted 28 June 2022 - 01:08 pm
.and it did a sizeable euro trip in 2006.......http://www.carpe-tdm...=2&showentry=33
#20
Posted 28 June 2022 - 04:25 pm
Triggers broom (no longer called "the tdm") got some fancy new wheels today...fancy because they are painted and have new bearings and tyres and discs and pads...thanks dabbers.
Lots more treats (mostly from dabbers) to go but that'll wait till winter.
