Bike hard to start, and will stall if not revved. Backfiring etc?
If not, project tdm for sale!!!
Posted 25 February 2018 - 01:04 pm
Posted 25 February 2018 - 01:12 pm
Posted 25 February 2018 - 02:18 pm
Posted 25 February 2018 - 02:42 pm
Posted 25 February 2018 - 03:09 pm
Might be worth removing the clips to see if there are any more cracks in the rubbers. Some crack around the rubber, under the clips.
Posted 25 February 2018 - 03:44 pm
Posted 25 February 2018 - 04:28 pm
There are loads of these cracks but only one rubber has them. I'll get two new ones and give it another go.
oh well another week in the car then! Photos are quite poor really, in real life these cracks are really pronounced
Edited by itchyfeet2, 25 February 2018 - 04:29 pm.
Posted 25 February 2018 - 04:44 pm
Get the bike running at tickover. Spray the areas where you think the rubbers might be leaking with something like WD40 to see if it makes any difference to the tickover. If it does you clearly have a leak
A typical symptom of airleaks would be a reluctance for the revs to drop quickly after revving from tickover ( bike in neutral) .
Posted 26 February 2018 - 12:09 pm
Posted 26 February 2018 - 12:14 pm
I don't think an airleak alone would cause all the problems you have described. I think there is something else going on - which sounds carb related to me.
Posted 26 February 2018 - 12:21 pm
I don't know about 850s or their carbs so I may be talking BS but my experience elsewhere suggests this could be a pilot jet / primary circuit blockage. Flooding might give some similar symptoms but you haven't described a strong smell of petrol so I ere towards a pilot jet type problem
Edited by thelodger, 26 February 2018 - 12:23 pm.
Posted 26 February 2018 - 02:38 pm
Are you using the choke to help start it ? Also, is the tickover high enough ?
Posted 26 February 2018 - 03:37 pm
put choke and see if that improves the running. then you know you are weak
