Posted 11 March 2018 - 11:37 am
Anyway first time on this bike, come to refilling and the oil keeps backing up out of filler tube!,!,!, its driving me mad, manage to put 2lts in but its been an epic.
Any ideas for a dim wit cheers Chris
Posted 11 March 2018 - 11:54 am
Filling the 9er requires patience. Any attempt to rush it and it'll back up. I change oil annually, which is around 3k.
Gorn
Posted 11 March 2018 - 12:07 pm
You did drain out all the oil? (two drain plugs)
Otherwise, yeah, slow n tedious job.
Posted 11 March 2018 - 12:49 pm
Needs to be on the side stand also.
Edited by dablik, 12 March 2018 - 02:04 pm.
Posted 11 March 2018 - 01:43 pm
I’ll do that next time, looked like I got all the old oil out.
We’re in the 21st century right? Never had these problems with any of my previous bikes, dirts included.
Anyway thanks for helping a very impatient dim wit, hopefully this might help others.
All done, washed and it’s back in the good books, cheers
Posted 11 March 2018 - 04:21 pm
Posted 11 March 2018 - 04:44 pm
On the 9r it's fill with 3.5 and crank over then top up and loosen the gallery bolt to check flow, just plonked the 4 litres in one go also many a time.
Posted 11 March 2018 - 07:05 pm
Cheers guys, did both drain plugs after warming up, didn’t have it on its side stand?
Seems you're ahead of our time and ready for this kind of bike :
Posted 11 March 2018 - 10:49 pm
oh Monsewer you is taking the oui.
Posted 12 March 2018 - 09:17 am
Needs to be on the side stind also.
This.
Posted 12 March 2018 - 09:50 am
Posted 13 March 2018 - 12:39 pm
I find using one of those funnels that has a particle filter in the base of the funnel bowl allows you to load ~500ml at a time, and the filter slows the rate to avoid back ups.
Bit like this:
Mine has a flexi bit so can keep bowl level and spout in the filler tube.
Edited by dmmsta, 13 March 2018 - 12:40 pm.
Posted 13 March 2018 - 05:32 pm
The original level was low hence the kick up the butt to change everything, but I didn’t have nearly 4ltrs of waste?
Oh well live and learn, new bike, new set of quirks.
Posted 14 March 2018 - 09:36 am
I've a similar funnel with a small handle so that I can use a bungee round the handlebar to keep it upright and not have to hold it in place. Doesn't particularly speed it up but makes it easier.
Bit like this:
