Bleeding Abs Brakes
Posted 16 March 2018 - 12:08 pm
Posted 16 March 2018 - 02:21 pm
When I bled the Fazer's, it's just the normal process as long as you're only knocking air out of the caliper.
If it's a complete re-fill or you've got air in the ABS module, then I think it's a bit more long winded as you need to bleed the module too etc - I've never done that so may be easy on the early systems, but not sure.
For your job sounds like a normal bleed should be fine though.
Posted 16 March 2018 - 08:35 pm
Bleeding the ABS brakes is a separate procedure.
When you just pump the DOT4 fluid through the lines it doesn't cover the ABS-unit.
To actually bleed the ABS-unit, as follows: https://translate.go...t-text=&act=url
This is a German-site. Hope the translation is correct. If you can read German: click in the upper right corner on "original text".
Be careful not to overload the ABS-pump! It could run hot if you repeat the pumping to often.
This procedure is also the most simple way to test the ABS system.
Posted 19 March 2018 - 07:48 am
Wouldn't it be possible to do this by strapping the brake lever overnight ? I did it on an ER6 where I had reinstalled the ABS unit, worked a treat !
Posted 20 March 2018 - 08:17 pm
That is a nice way to get the air out of the system, but it won't refresh the brake fluid in the ABS-unit.
The only proper way is to activate the ABS-pump as described in the link.
Posted 21 March 2018 - 08:51 am
...but this was about bleeding, wasn't it ? Or did I miss something ?
Posted 21 March 2018 - 06:28 pm
Your quite right! Sorry!
I've misread bleeding for changing the brake fluid
Must be the language and I'm getting old
