I can try to bypass the sidestand switch, but I'm not convinced - the bike should run on the sidestand in neutral with the clutch released, no? It always did in the past.. the neutral light is illuminated, so the bike knows it's not in gear, and as noted before the behaviour is the same whether the sidestand is up or not.
I found this thread http://www.carpe-tdm...showtopic=33992 which describes some similar issue... It's not clear where the relay in question resides, but could it be in the same relay that I've just had to repair the connector? Could the repair be at fault, or could the relay have blown?
If I do try to bypass the sidestand switch, I assume I need to replace with an open circuit, right?
