Fuel Pump Issue
9 replies to this topic
#1 Rip
Rip
  • 3 posts
Posted 18 May 2022 - 08:23 am
Hi all, I'm new to all of this, I'm in my later years so please bare with me. I have just picked up a tdm 850 2000 4tx, been standing for 10 years, sonically cleaned carbs and recommissioned, bike runs and ticks over fine, but I have an issue with the fuel pump doesn't engage whilst the kill switch is engaged, I can hear the relay click when the kill switch is in the on position, but the fuel pump doesn't engage? Have bipassed and gone direct to the battery to the pump and the pump works fine and the bike starts off the button, my next step is to check regulater rectifier voltage. Is there a way to test the fuel relay or the green 5 pin relay and know what this does and is fie?
Thank you all in advance for your time and knoweledge.all input is greatly appriciated!
Rip
#2 fixitsan
  • 4,676 posts
Posted 18 May 2022 - 08:50 am
I thought the fuel pump on the 850 was vacuum operated (my three were), so I never heard a fuel pump operate
#3 Rip
Rip
  • 3 posts
Posted 18 May 2022 - 08:59 am
Hi early models were vacum later electric pump ,which works fine just wont engage on ignition
#4 Snowbird
  • 1,357 posts
Posted 18 May 2022 - 09:21 am
If there is fuel pressure in the system you won't hear it tick, it only ticks when the bike has been left for a while, maybe drain the carb bowls (or just run for a while with the fuel tap off, long pliers should reach it via the left hand side fillet panel) and turn on the ignition to see what happens.
#5 Catteeclan
  • 2,440 posts
Posted 18 May 2022 - 05:21 pm
Or prob the positive wire to the pump maybe.
Edited by Catteeclan, 18 May 2022 - 05:21 pm.
#6 Rip
Rip
  • 3 posts
Posted 18 May 2022 - 07:29 pm
Hi thanks for replying , I'm at balance stage with tank off and been running on bottle direct to battery fine and can hear pump works fine but put back as should be and no bottle just fuel in carb's and run's no pump ,relay clicks when kill switch is turned on, will run for longer laterer when home just be sure but normally pump goes pretty quickly
#7 thai850
thai850
  • 13 posts
Posted 19 May 2022 - 02:15 am
vapor lock maybe?
#8 ChrisG
  • 8,276 posts
Posted 19 May 2022 - 10:24 am
Does the sidestand switch cut the fuel pump, or is it the same relay that the kill switch uses?
#9 MipeTDM
MipeTDM
  • 92 posts
Posted 21 May 2022 - 12:24 pm
The contacts inside of the relay may be dirty/corroded. You can pull out the relay and connect the respective pins that the relay connects when activated, with e.g. a string of wire, or a paper clip. That way, you can also rule out any other wiring issue.
Or, if you have another similar relay (laying around or on the bike), you can just try to swap it.
Edited by MipeTDM, 21 May 2022 - 12:25 pm.
#10 fixitsan
  • 4,676 posts
Posted 22 May 2022 - 09:00 pm
And if it turns out to be the relay share the part number written on the side of it. I was just about to throw a couple away, but I'll keep them for longer in case needed
