Went to see a suspension specialist, this morning, and apparently the damping modules on the forks are broken (cause TBD and something he'd never seen before) and the damping in the rear shock works, but is at the wrong setting and the adjuster is broken (or the needle is stuck).
So essentially my suspension is shagged.
As luck would not have it, it's the forks that the biggest headache as who knows what has happened for the damping and its adjusters to have no effect on fork function.
I do know that one of my stanchions ( and only one, mind) is quite heavily pitted: perhaps this is a sign of a previous rebuild where the other fork had been reworked.
Beyond that, I probably need to buy the damping internals, but all that is to be confirmed once its opened up.
He's going to looking into options, but I'm going to ask here and see if any of you know a good place to find spares for niner forks. Or perhaps some of you have bits lying around.
eBay is obviously one place, but do you know of any others? Also, if you happen to know of other bikes that share parts compatibility with the TDM, Id love to hear about it, to help broaden my parts search
Edited by SeizedBalt, 14 June 2022 - 07:38 am.
