Fork Oil Level
Posted 17 June 2022 - 09:11 am
As previously mentioned, both my new fork seals are leaking.🙁 When I was refilling the forks, the manual says to fill with 507ml of oil with an air gap of 133mm. However, after pouring in the required amount the air gap was bigger than 133mm. As I had completely rebuilt the forks rather than just changing the oil, I thought it not unreasonable to assume you might require some extra oil so filled the fork legs to get the correct air gap. This meant that I had to put 520ml into each leg.
So my (dumb?)question is, would the additional oil cause extra pressure to build up within the fork and result in oil being forced past the seal? I know, clutching at straws😀,but curious to know what effect putting in to much oil would have,other than stiffening up the suspension.🤔
Posted 17 June 2022 - 10:55 am
I'll be blunt.
It is a stupid question when it does not include the details of the bike - model, year.
"Previously mentioned" doesn't cut it - I am not going to search back to find the relevant thread / post.
- and your TDM model info. says "no more"
Posted 17 June 2022 - 12:27 pm
I'll be blunt.
It's a 2003 900. Apologies for not including that info.
Posted 17 June 2022 - 03:32 pm
The manual says first fill, then stroke/wait, then measure, and if the oil level / air gap is wrong correct it. In my experience this is the usual method - the oil volume is approximate, the level accurate.
So set the air gap using extra oil as you have done.
The air gets compressed and adds to the spring effect, and the standard gap should give the standard air pressure inside that the seals are designed to cope with. In other words if you still get a seal leak it is not the fault of the air gap / "extra" oil - all assuming you have done the rebuild correctly.
Good luck.
Posted 17 June 2022 - 09:31 pm
Posted 17 June 2022 - 09:56 pm
Check the tubes carefully for any out of roundness...odd wear. Then try again.
ಠ﹏ಠ
Posted 18 June 2022 - 06:12 pm
ಠ﹏ಠ[/quote]
I'll check them but the old seals got it thru its Mot a few weeks ago so I'm assuming the tubes are ok.
I was pretty sure it wasn't the extra oil that was causing the problem but I thought I'd ask anyway, clutching at straws.🤣
It's probably the pattern parts from Wemoto or my method of fitting them. In the absence of the official tool, I used the old seals to drift the new ones in as far as possible and then very carefully tapped round the edges to move them down the last few mil. I also seem to recall from a previous thread that the seals should be fitted with the flat side up and that's the way I fitted these ones. Is my method ok or anything I should do differently?
Posted 19 June 2022 - 06:52 pm
yes there is Johnny, please put the cream on yer scones first followed by the jam as the Cornish are always blasting us Devon residents for not following their method.
Posted 19 June 2022 - 07:11 pm
NO! Jam first then the Cornish Clotted cream
Posted 19 June 2022 - 07:29 pm
Posted 19 June 2022 - 08:00 pm
👍Ewe could try a bit o PVC poipe to drive the seal on. Protect or wrap the edge first to give it a larger contact patch and protect the seal argh arrrgh. Arrrrrgh.
Sorrry Wicky, I'm a jam first guy.😀😀
Posted 19 June 2022 - 08:19 pm
I found a length of aluminium tube at work the right size and ground a slight taper inside to cater for the lip and used that as a slide hammer, did fine and not leaked.
That was with oem seals from fowlers though after filing across the rust pit I found on the tube and dabbing clear nail varnish over it to smooth the edges.
Next time it leaks the tubes will be off to luton for a re-hard chrome and grind.
