Edd China Series
32 replies to this topic
#21 dapleb
  • 18,104 posts
Posted 31 July 2021 - 08:42 am
It's all for telly, just to look good, the real work gets done by others, probably outside firms.
It definitely doesn't. This is almost real time.. showing all the problems and fiddly time consuming things, including tea breaks. This series makes me feel better about why it takes me hours and hours and hours to do a simple task. ◉‿◉
#22 dablik
  • 10,735 posts
Posted 31 July 2021 - 10:15 am
Not only you daps, makes me feel better as well  :lol:  and the boo boo at the end.
#23 drewpy
  • 1,753 posts
Posted 31 July 2021 - 03:33 pm
I enjoy my fridays' watch the china crisis.
that mini is a bitch to work on
#24 dapleb
  • 18,104 posts
Posted 31 July 2021 - 04:09 pm
No tv ear so it's my only weekly viewing and handily released on the only night I have enough time to watch it.
ƪ(‾.‾)┐
#25 leehenty
  • 5,080 posts
Posted 31 July 2021 - 05:13 pm
I watched him stick a screwdriver in an abs sensor and lever it out, I thought "he will bust that"
#26 leehenty
  • 5,080 posts
Posted 31 July 2021 - 05:25 pm
https://youtu.be/tQKxivbsFFE
An exercise in now get out of that. Spark erosion.those easy outs were invented to.kerp these guys on business
#27 Catteeclan
  • 2,433 posts
Posted 01 August 2021 - 08:52 am
Thats some bloody clever kit. Can you knock me one up Lee? Couple of hundred cover it? :lol:
#28 dapleb
  • 18,104 posts
Posted 01 August 2021 - 08:59 am
Soft on the inside crunchy on the outside....or is that armadillos.
Best thing for abs....binnnnn
#29 leehenty
  • 5,080 posts
Posted 01 August 2021 - 06:54 pm
Circa £4000 for a decent one
#30 Studley Ramrod
  • 19,202 posts
Posted 01 August 2021 - 07:07 pm
Ed Said he thinks that's the sound of the alloy threads stripping sooooooooo, surely just a quick helicoil will fix it ?  165Nm is a lot for a small looking bolt. :dunno:
#31 dapleb
  • 18,104 posts
Posted 01 August 2021 - 07:58 pm
Yeah steel bolt into alu and maybe it was 180nm or 200nm or 150nm.
Some bloke who obviously does this regularly said they always timesert or helicoil when it's off regardless....as they know if they don't they will most likely strip.
He also said the threads are cut with tri-lobe bolts at factory and him cleaning it up with a standard die may have altered the way the bolt contacts and helped the failure...either way it's bust and will need more fettling...how refreshingly realistic!
#32 PICARD
  • 1,741 posts
Posted 01 August 2021 - 09:22 pm
:lol:
Arrrgghhh no....my pet hate...claw hammer for engineering!!
#33 leehenty
  • 5,080 posts
Posted 08 August 2021 - 08:24 pm
Claw hammer has no place in engineering workshop.
When I did Moose's VFR stator, it had those funny trilobe bolts. Doesn't really cut a proper thread. All of them broke trying to put them back as the shank is around 4mm. Well I didn't break any much but Moose made up for it. Ping shit, ping shit, bugger was the mantra. Lee have you got any helicoils ?
Still miss miss him and his drawings of stuff he wanted.
Edited by leehenty, 08 August 2021 - 08:24 pm.
