Gaiters?
22 replies to this topic
#1 Deauman
Deauman
  • 109 posts
Posted 17 May 2013 - 10:01 pm
I've got a blown fork seal on a 900 that's done less than 8000 miles.  It occurs to me that some good old fashioned rubber gaiters might help to stop this happening again.  Has anyone here fitted gaiters?  What size is required?  Do they look ok or completely naff?
#2 leehenty
  • 5,093 posts
Posted 18 May 2013 - 07:14 am
gaiters need about 43mm top, anything around 40mm will do they stretch, allow for 150mm of fork travel, bottoms need to be about 50-60mm. They do work. Chect your stanchions for small pits or dings on the bit that slides through the seal.
#3 Studley Ramrod
  • 19,217 posts
Posted 18 May 2013 - 08:49 am
Probably doesn't help having crater sized potholes everywhere. :rolleyes:
#4 TKH
Posted 18 May 2013 - 06:36 pm
I've fitted gaiters to mine got them from here:
http://www.ebay.co.u...=item337fcab741
But I think you either like 'em or hate 'em.
#5 charlietbird
charlietbird
  • 127 posts
Posted 18 May 2013 - 08:01 pm
I fitted a pair to my Mk1 a couple of weeks ago, looks pretty good!
Charlie
#6 RolfieB
RolfieB
  • 1,069 posts
Posted 18 May 2013 - 08:16 pm
This is my personal preference.
Oops sorry my mistake, it's gaiters not garters.
Now I just fly everywhere.
Gone to new owner.
Black Mk2a
#7 shadowjack
shadowjack
  • 173 posts
Posted 18 May 2013 - 10:22 pm
To be fair, a mistake we've likely all made, from time to time...
#8 masterbrewer
Posted 19 May 2013 - 12:52 am
Shall we take a polle?  ............................ errr ! ............. she won :good:
Anyhow here's mine
Edited by masterbrewer, 19 May 2013 - 12:55 am.
#9 Kelpie
Kelpie
  • 944 posts
Posted 19 January 2023 - 05:39 pm
Anyone know if Arthurbikemad is still selling fork gaiters? BSM is doing fork oil change on both bikes at the moment, and our ancient gaiters need replacing. Ive tried messaging Arthur on eBay but no response.
#10 ramo
ramo
  • 1,179 posts
Posted 19 January 2023 - 10:59 pm
I just bought some of these,
https://www.ebay.co....tm/284436750945
they are the same size as what other sellers list for the TDM 900,
50x35x205cm, I will be trying to fit them next week, but not lost a fortune if they don't,
I'll post up and let you know if they were successful
#11 Kelpie
Kelpie
  • 944 posts
Posted 20 January 2023 - 07:01 am
Thanks Ramo, much appreciated.
#12 leehenty
  • 5,093 posts
Posted 20 January 2023 - 10:26 am
Will 35 mm be a bit too stretched over the 43mm stanchions ?
#13 ramo
ramo
  • 1,179 posts
Posted 20 January 2023 - 02:29 pm
I don't know Lee, but Ill give it a go,
its only  so lets 7mm difference so lets hope so, plenty of lube
#14 Snowbird
  • 1,361 posts
Posted 20 January 2023 - 06:58 pm
That's what micheal jackson said... :huh:  (alledgedly)
#15 leehenty
  • 5,093 posts
Posted 21 January 2023 - 12:26 pm
Niner riders..
#16 Kelpie
Kelpie
  • 944 posts
Posted 24 January 2023 - 03:44 pm
Unfortunately they dont fit.
#17 ramo
ramo
  • 1,179 posts
Posted 24 January 2023 - 08:30 pm
Yep Kelpie
you are correct, I changed the oil in my forks, so had a go,
too tight, I will have to look for another supplier,
I should have made a not of the size when I fitted the Arthur ones last time
#18 ramo
ramo
  • 1,179 posts
Posted 01 February 2023 - 02:29 pm
Right these fit
https://www.ebay.co....tm/114499609194
I've a picture of them fitted, but Studley is not allowing me to post it, say's file too big,
I have tried resizing 3 times and given up,
if anyone wants a pic, PM me your email address
#19 leehenty
  • 5,093 posts
Posted 01 February 2023 - 03:03 pm
Like this?
#20 Kelpie
Kelpie
  • 944 posts
Posted 02 February 2023 - 08:26 am
Thanks Ramo! 2 pairs on their way.
