New Clutch - Too Thick?
18 replies to this topic
#1 Bjørge
  • 1,792 posts
Posted 26 May 2020 - 04:13 pm
I changed the clutch yesterday, and I must say it seemed like the new plate stack was thicker than the old one. Well, assembled dverything and when testing today the clutch doesn't seem to free up properly 😐
I bought from Wemoto, EBC friction plates and Gekko steel plates. Also fit shorter springs to make it comfortable, but I assume this will affect grabbing effect - not keeping the clutch from freeing up 100%.
Oky, I won't get my money back, so considered removing 1 pair of plates and fitting the old, longer springs.
Any ideas, anyone?
#2 drewpy
  • 1,758 posts
Posted 26 May 2020 - 04:15 pm
did you soak the plates in oil overnight?
#3 dablik
  • 10,757 posts
Posted 26 May 2020 - 05:01 pm
Hm interesting, i've fitted a complete new set from Wemoto, both plates Gecko but i had to leave the original smooth steel friction plate (1st plate) as was not in the kit, have you put the smooth plate, ie no dimples in ! mine clutch seems to be working okay although the bike is static.
#4 Bjørge
  • 1,792 posts
Posted 26 May 2020 - 05:34 pm
Same experience, had to keep the inner plate as it wasn't in the kit.
Nearer to fortnight than over night😀
Edited by Bjørge, 26 May 2020 - 05:33 pm.
#5 dandywarhol
Posted 27 May 2020 - 12:47 pm
Not sure what you mean by "Comfortable". Shorter springs will increase the lever effort (like shortening road springs on yer Vauxhall Corsa will give your passenger nipple rash because the ride will be firmer :pimp: ) .They might also become coilbound and not let the plates separate properly.
#6 drewpy
  • 1,758 posts
Posted 27 May 2020 - 12:52 pm
they will be tdm900 springs so should be fine.
you don't need to pull as far to release the clutch. I think that was meant by comfortable.
I have them on mine and I prefer the shorter clutch pull.
#7 dandywarhol
Posted 27 May 2020 - 06:49 pm
Ok thanks for that. Are the 900 springs a lighter gauge wire? What do you need to do to allow for the shorter spring and to allow the plates to separat?
#8 Bjørge
  • 1,792 posts
Posted 27 May 2020 - 07:47 pm
The springs press plates together (=engaged clutch), so shorter or weaker springs could possibly cause slip and not less freeing up. When you pull the lever, you overcome spring pressure. I wanted a longer action from free to fully engaged, as I always found the MkI clutch to be an operation challenging left hand precision...
Edited by Bjørge, 27 May 2020 - 07:49 pm.
#9 drewpy
  • 1,758 posts
Posted 27 May 2020 - 08:35 pm
no they are stonger but you don't need to pull them as much
no issues whatsoever with slippage or separation. I assume the clutch hasn't changed between models.
I think I got the info from this site
found it
http://www.carpe-tdm...clutch +springs
Edited by drewpy, 27 May 2020 - 08:39 pm.
#10 wicklamulla
Posted 27 May 2020 - 10:42 pm
you sure they are TDM 900 springs and not 1999 onwards TDM 850 springs?
#11 dandywarhol
Posted 28 May 2020 - 10:20 am
Are you sure the shorter spring's coils aren't touching together when you pull the lever and the plates aren't separating fully because the travel is shorter?
#12 drewpy
  • 1,758 posts
Posted 28 May 2020 - 10:47 am
no not sure now.  was a while ago
#13 Bjørge
  • 1,792 posts
Posted 28 May 2020 - 01:47 pm
Yes, because they were roughly same wire diameter.
The problem is that after ~half travel it starts freeing but doesn't fully disengage upon fully squeezed. Very little happens, which I believe is consistent woth the idea the whole stack fills too much hence no room for free turning.
I will have to disassemble, but don't know yet what to do - put in old plates or try remove 2 of the new ones.
Btw:
Is placing the bike on side stand sufficient for removing clutch cover w/o draining oil?
Edited by Bjørge, 28 May 2020 - 01:48 pm.
#14 Nog
Nog
  • 514 posts
Posted 28 May 2020 - 04:01 pm
Yep have done it myself without issue.  You might lose a tiny amount as you take the cover off, so put a container under to catch it.
If you really want to make sure, put a couple of thin planks of wood under the tyres, so it will lift it a touch more and the angle will be more than usual and really get all the oil over to the left side of the bike.
#15 Bjørge
  • 1,792 posts
Posted 28 May 2020 - 04:27 pm
Thanks! What I need to know 😎
#16 dablik
  • 10,757 posts
Posted 28 May 2020 - 07:02 pm
oem number given in the other link in the other thread, when linked search is furra 99..
#17 wicklamulla
Posted 28 May 2020 - 10:15 pm
Just as i thought.  The 1999-2002 TDM 850 dimpled clutch plates are the ones you can retrofit to earlier TDM's.
#18 Bjørge
  • 1,792 posts
Posted 30 May 2020 - 11:55 am
Solved!
I overlooked the fact that there were 7 regular steel plates and a special one at the bottom of the stack.
The kit that I bought contained 8 regular steel plates and I threw them all in.
Stupid me 😐
But- most importantly; the clutch feels fantastic! Much longer action, not the on/off feel from last 70,000kms
Just need an oem clutch cable, the one I got is really crap from new - you really feel each cord as they grind tveir way
Now- to polishing 😎
Well, they're shorter but a tad bit thicker wire. So I put in the originals. The clutch tured out good, so I'm happy
Edited by Bjørge, 30 May 2020 - 11:55 am.
#19 drewpy
  • 1,758 posts
Posted 30 May 2020 - 03:31 pm
good to hear
