Rough Running Below 4000 Rpm, Help!
Posted 28 May 2010 - 04:38 pm
I have a 1998 TDM 850 with 35,000miles, bought 1 year ago and hasn't run right since.
Standard I think apart from an Arrow stainless 2-1, which isn't loud at all...
Lots of hesitation below 4000 rpm, after which it runs perfectly, plug chop reveals normal colour. Seems good on petrol, despite not needing choke to start, which it does easily.
Ticks over a little roughly and can be ridden, but not happy below 4000, nightmare round town, worse when hot.
Replaced 1 coil, 2 plugs, new carb rubbers, cleaned carbs and shimmed valves with no effect, although I think it was better for a short while after the new plugs and coil, might have been kidding myself though....
The mechanic proposes messing about with float bowl heights but I think electrics more likely, but really, God knows......
Where would people start???
Posted 28 May 2010 - 04:47 pm
do you have a dyno run with fuel/air mixture reading throughout the rev range?
Posted 28 May 2010 - 05:01 pm
well, the previous owner claimed that there were new carb parts fitted (did he say brass jets or something?) but now I'm beginning to doubt his word........
nothing so hi-tech as a dyno run here I'm afraid.......
I thought I read that emulsion tubes were linked with high fuel consumption.....I've just emptied a tank in 175 miles, mostly at 100mph + which doesn't sound too bad?
But I'll take any advice
Posted 28 May 2010 - 08:30 pm
I had all your problems apart from yours getting worse when hot and tried to clean the carbs with what I had but it was still there.
In the end I paid for a mechanic to look at it and it ended up being one of the holes in the carb body that was blocked completley.
This was causing it to run on one cylinder, especially poor at low revs and town riding.
Seemed to be OK above 4000 rpm.
He was amazed I was able to ride it at all.
Mine went " CLUNK CLUNK CLUNK" at 2000 rpm and below in second.
It runs like a dream now and it's so nice to get those revs down around town and do a bit of filtering without ALWAYS using the clutch.
Posted 29 May 2010 - 09:59 am
Generally speaking, a problem that gets worse when the engine warms up is a sign that the bikes running rich. It could be bogging down at low revs and if the emulsion tubes are new and all the gaskets and o rings are good then I'd go with the mechanic's proposition.
As Sweep mentions also, it could be a blockage or air leak somewhere.
I doubt it's an electrical problem.
Posted 30 May 2011 - 07:33 pm
Can I now add that carbs have been balanced, float needle valves replaced, float heights measured, new battery, but still the problem persists although not as bad - but trying to filter in traffic, hold a constant low speed or ride hairpins 2-up in anything other than 1st gear is all horrible!
It is slightly worse when hot, never needs choke and when it does cough/hesitate it gets better if I throttle off a little, leading me to suspect it's running rich...........
Incidentally, I ordered some of the emulsion tubes, but my Bulgarian mechanic (old-school engineer) reckoned the existing ones were better quality than these new special ones (at about 50 quid!) or should I just override him?
Anway, big thanks to all those offering help - I really want to enjoy this bike!
Edited by bulgariantdm, 01 June 2011 - 08:03 pm.
Posted 31 May 2011 - 08:07 am
Sounds like the emulsion tubes need replacing, also worth checking/replacing the choke plungers and also the pilot adjustment screws.
