3Vd Speedo Cable And Now Other Tinkerings
#41
Posted 23 April 2020 - 05:27 pm
#42
Posted 23 April 2020 - 06:24 pm
At least 10.9 daps, han gon ill go look for length......thems what i bought BUT hold fire i wanna make sure they are 1.25 pitch, quite sure but rather check tomorrow as i've bought so much shoite lately.......so looks like 60mm long plus enough for ya crash bar, prolly 65mm, prolly txt info as no access to pc in day.... no 65mm only 70mm..
Edited by dablik, 23 April 2020 - 06:26 pm.
#43
Posted 23 April 2020 - 06:55 pm
Are yours hex head? They is recessed so not sure there would be room for hex (as in linky dink) rather than Allen?
#44
Posted 24 April 2020 - 05:35 am
You'll need Hex heads to fit the engine bars for sure daps, my bars not currently fitted cos aint finished yet but previous with Hex heads, i'll go out soon an measure up for ya, need a bit brekky, then if i can get on ere will post or send info, swmbo working from home an a early bird xx
#45
Posted 24 April 2020 - 05:40 am
#46
Posted 24 April 2020 - 06:23 am
Okay dappers check ya phone for pics matey, cant upload onto pc just now as her is shifting me off the pc....
M10 x 60mm hex head 1.25 pitch... per the ebay link bud...
#47
Posted 24 April 2020 - 07:55 am
Got sizes now ta to you so will have another look and see if oi can be bothered or no.
I like that the bars don't attach direct to enjun as that seems very daft to me and asking for a bust enjun.....but I do like a tinker and the side panel dangling might drive me nuts.
#48
Posted 24 April 2020 - 04:30 pm
That's approx 5mm out to simulate engine bar fit
DSC_0163.JPG 83.75KB 0 downloads
Plenty through the mount
DSC_0165.JPG 112.02KB 0 downloads
Also ifya need to know the normal Alan head bolt through the frame holder recess is 45mm from end to under the head
#49
Posted 24 April 2020 - 05:41 pm
I gave the bars a clean today and tweaked the bracket straight on one side.
And found the headlight protectors.
Yer boike so lubbly and clean and shiney dabs.
#50
Posted 24 April 2020 - 07:57 pm
Ok great ta. I can't be downloading your uploadings for some raisin. Don't think me phone does pics.
i agree do a point, i have seen some bars (on all manner of different bikes) which appear to have over long lever point attachments that look ripe for crank case destruction.
When i fitted the Renntec enjun crash bars to No.7 i decided to use a long threaded bar to attach them (same crankcase holes that the 3VD alloy bash plate mounts thru) instead of the 2 supplied shorter individual bolts simply cos i reckon it spreads the load and forces over 2 sides instead of 1. I have tested the theory a few times and the Renntecs have saved the day nicely and me cranky cases are intact.
I have bought a set of the RD Moto ones (in my link several posts back) for me 3VD as i reckon they offer more protection for the side panels allied to similar protection around the enjun akin to the Renntecs. Oil suck it and see.
Dablik she's looking new new new and as Madonna would say 'Loike a Virgin'.
#51
Posted 25 April 2020 - 07:11 am
Yes daps 60mm will do it, ya can go a bit longer you want as enough room behind the mount..........
Frame holder recess is simply where the original mount bolt sits in it's recess when tightened up.....that bolt is 45mm and your replacing it with a longer hex head for engine bars..
Yep she's clean chaps and that is a bit of a problem, keep finding shitty bits all the time...
#52
Posted 29 April 2020 - 08:38 am
Headlight protectors fitted with 1cm clear 3m dual lock dots.
New Speedo cable fitted. On comparison with oldun there is no visible sign of wear on old inner. So I'm not convinced this will fix the wag but a good first step.
#53
Posted 29 April 2020 - 09:14 am
Not sure how I ever managed to find time for work!!!
that stuff is amazing, it holds the headloight protector in situ on my 4TX. I'd loike a 3VD set too though.
#54
Posted 05 May 2020 - 12:37 pm
#55
Posted 05 May 2020 - 03:09 pm
#56
Posted 12 May 2020 - 02:56 pm
Boike back together and run to temp, alles goed.
#57
Posted 12 May 2020 - 03:55 pm
Are you planning on using it when we get the green light ?
#58
Posted 12 May 2020 - 04:23 pm
Bars fitted. Look quite neat. Hope not to do any investigation as to how effective they are.
Ride out Batman
#59
Posted 12 May 2020 - 05:43 pm
#60
Posted 12 May 2020 - 06:22 pm
Oh your gonna need that ride out soon then, good luck
