Alrighty!
Got an ecu, wiring harness, recitifer, and ignition coils from a German motorcycle parts warehouse.
Genuine 3VD ones ? you were lucky !
Posted 24 April 2020 - 04:20 pm
Alrighty!
Posted 24 April 2020 - 07:08 pm
Does anyone have a decent exploded parts diagram from a manual? I may just end up buying a manual if I can find one
I've emailed a copy of the parts fiche to you.
Posted 15 May 2020 - 01:14 pm
Posted 15 May 2020 - 02:24 pm
Posted 17 May 2020 - 11:27 am
4TX ecu will not work with 3VD engine. Firing order is all wrong.
Lee i agree but someone once said to me that it may work due to being a wasted spark ignition?? I still reckon the ignition signal pulse will fire at the wrong time, what say ye all?
Posted 17 May 2020 - 11:59 am
4tx is a 270 degree firing, 3VD is 360 degrees. I assume the spark firing timing of cylinder 2 will be out of kilter
Posted 17 May 2020 - 02:35 pm
From memory, someone used a 3vd ecu with a 4tx engine, or vice versa. It's the timing signal from the rotor magnets that determines when it sparks. Soooo, should work in theory.
Posted 17 May 2020 - 02:52 pm
well i can assure you guys , that i had a 4tx cdi , and that thing never fire up any of my 3vd ......
Heres a link to photos on another thread
https://www.motohous...074#post4194074
From what I can tell I will need:
1. Carbs
2. Wiring Harness
3 Spark plug wires
4. Radiator/plumbing
5. Clutch Cable
6. Shift Lever
7.Exhaust
Thats all I got if you see something I missed fill it in
if you are still in need any of this or other material , let me know i still have plenty of spare parts from my projects !!
Posted 17 May 2020 - 06:20 pm
Your correct mucka as i remember also, so assume from the previous post a superior 3vd cdi may well fire the lesser mk2
Posted 17 May 2020 - 09:05 pm
More than likely. Glad you also remembered, saves me searching for the post.
Posted 17 May 2020 - 09:07 pm
MickC possibly !!
