So is the info on that pic on the previous page incorrect?
No. Look at the overall length of the body/barrel, the 34mm new one is longer overall.
Posted 18 May 2020 - 11:02 am
Posted 18 May 2020 - 11:46 am
ok tangs very much as i was confuzzled. Randy Borehole just rang me and tried to explain it to me but he's a foreigner and i cudn't understand a word he was saying.
Posted 18 May 2020 - 11:58 am
Oi tink ............... feck it, can't keep it up, I think the original tensioner with the short body INSIDE the engine allowed the plunger to flex and occasionally stick in the body as the chain drags against it. The longer body offers more support
Posted 18 May 2020 - 02:47 pm
Posted 18 May 2020 - 03:02 pm
It's the longer length inside that matters, longer inside keeps plunger from binding.
Posted 18 May 2020 - 03:09 pm
That's what she said!
now that's spoken loike a TDM 850 rider!
Posted 18 May 2020 - 05:35 pm
Posted 18 May 2020 - 07:26 pm
That's clarified it then chaps.
Posted 20 May 2020 - 08:25 am
Edited by SeizedBalt, 20 May 2020 - 08:25 am.
Posted 20 May 2020 - 09:18 am
Posted 20 May 2020 - 09:44 am
If you are going in to replace camchain and do valve shims, putting new later type tensioner is essential.
Posted 20 May 2020 - 10:22 am
Edited by chrisr, 20 May 2020 - 10:36 am.
Posted 20 May 2020 - 10:55 am
Presumably the tensioner has now done its job? But Id still put a new one in.....
My thoughts too.
How many miles on the chain ? I changed one at 100,000 miles and it was not too bad. I changed another at 60,000miles and it was alright. in both cases there was slack, which affects valve timing, but it's worth a couple of degrees crank rotation at the most.
If you have the old style change to the new one, job done.
As for valve shims, the gap often closes up with time. Never going to show up as a problem except when the engine gets really hot, when you'll notice a slight loss of power under load at first, so it's worth at least checking them if you have no other way of knowing when they were last checked
Posted 20 May 2020 - 11:07 am
Posted 20 May 2020 - 11:43 am
I'd go for changing the tensioner only, as:
- it's a known problem
- it takes 15 minutes (as opposed to a full valve/chain job)
- it's relatively cheap
- I'd hate listening to that sound (you would not wait until it's permanent if you're afraid of what might happen)
- TDMs chains are usually running longer (my MKI has 113,000kms on orig. chain - no noise)
Posted 20 May 2020 - 12:16 pm
Posted 20 May 2020 - 12:50 pm
I'd do CCT and clearance check only, camchain is a big job for 45,000miles.
Is it such a big job, though?
I mean obviously it's nothing to be sniffed at, but if the cams are already out for the shims, is it so much more work to drop a new chain in?
And that's not me being facetious: I don't know the full procedure but from the little the mechanic told me it's not "engine out" territory.
Posted 20 May 2020 - 01:16 pm
There is a reason for the updated CCT - the original had problems due to the plunger sticking in the short body. The new one has the same part number but the last numbers on the original 5PS1221010 - 00 denote the early one. Unless someone sells you old stock with the - 00 then the 5PS1221010 is the new part for you. The engine was never subject to a recall so I'd be surprised if a dealer would give it free because Yamaha won't pay them for it.
Dealers only replaced the part under the Manufacturer's warranty if there was a noise - at 45,000 miles (on the clock) I would suck it up and change for the newer one for peace of mind. They have been known to jump teeth and they will run 2 teeth out without the valves hitting the piston - if it jumps 3 - well.....................
If it's a cost thing (understandably) then get a used one with the longer body - as far as I'm aware the superceded CCT causes no problem.
Edited by dandywarhol, 20 May 2020 - 01:19 pm.
Posted 20 May 2020 - 02:54 pm
Well, it is a cost thing and it isn't:
I mean, I'd rather the bike shop pay under their used bike warranty, but don't fancy having the bike make the noise more and more often, Sod's Law intervening in such a way that it went away the moment I turned into the dealer's carpark and eventually something goes wrong, or it's 2 weeks before our planned departure and the workshop is fully booked!
So, probably, I'm going to just get it done. It helps to get other opinions to see if I'm being unnecessarily impatient, or unwisely risky in what I'm thinking.
My take here is leaving it and waiting, now that it's started making noises is probably not a good idea.
Edited by SeizedBalt, 20 May 2020 - 04:06 pm.
Posted 20 May 2020 - 03:18 pm
Fit a new one, peace of mind is everything. Just ask Dabbers.
