Triumph Forum
Started by
, Apr 20 2021 06:39 pm
3 replies to this topic
Posted 20 April 2021 - 06:39 pm
Triumph forums are nowhere near as useful as here. Triumph want £55 for the backlash gear holding tool. A bit of bent 6mm rod with a 4mm pin.
So I'm making my own.
Posted 21 April 2021 - 05:25 am
I'm surprised you even looked for the triumph tool Lee, or was that just design research?
Posted 21 April 2021 - 08:19 pm
I just wanted to know what it looked like
Posted 22 April 2021 - 06:20 am
£2 for the tool, £53 for the 'T' logo ?
