Heating Oil Tank Isolation Valve
39 replies to this topic
#1 dapleb
  • 18,114 posts
Posted 09 April 2017 - 08:41 am
Morning carpedIans,
Does anyone one know how to turn off an oil tank?
The white pipe is the feed to the house.
The weird knob thing does not turn. I suspect this should turn and is the isolator??
The only other option is to remove and plug the feed to the house which could get messy!
Any help appreciated.
#2 PICARD
  • 1,741 posts
Posted 09 April 2017 - 09:19 am
Does the knob....wait for it....above the white pipe push in or pull out. Looks like it locks the isolation valve.
#3 dapleb
  • 18,114 posts
Posted 09 April 2017 - 02:13 pm
Aye aye cap'n. It says "Pu?? To read". So is just a wee ball valve to read the level. Neither puSH or puLL seem to do much though.
I will have more of a dig if no one knows. Couldn't find this setup onlion and didn't want to make a potentially big mistake with exploratory investigations!!
#4 PICARD
  • 1,741 posts
Posted 09 April 2017 - 03:17 pm
OK. Tried pushing the big handle thing inow, then turning it.0 These are sometimes lock safe valves.
#5 Studley Ramrod
  • 19,213 posts
Posted 09 April 2017 - 03:43 pm
The big knob should turn to isolate the supply, I think.
https://www.fueltank...ankmaster/p4965
Get some Stillies on it, I dare ya. :lol:
#6 Favs
  • 4,395 posts
Posted 09 April 2017 - 03:45 pm
Looks like this ?
https://www.fueltank...CFcsK0wod2z0CrQ
Snap
Maybe some diesel will free it off...................getting my coat now
Edited by Favs, 09 April 2017 - 03:48 pm.
#7 dapleb
  • 18,114 posts
Aye aye capn will give that a go.
Cannae get that site to load on my bone SR. But oi will give it a tweak. :-)
Thanks chaps.
#8 dapleb
  • 18,114 posts
Posted 09 April 2017 - 04:00 pm
Ahaa thanks again. I could see Atkinson in SRs URL, so googled that ... Then after 10mins reading dodgy diet advice, I added "oil tank " to the search and there she blows!
http://www.fueldump....ight-Gauge.html
Right time to get the blow torch oot to loosen that badger up! :-)
#9 dapleb
  • 18,114 posts
Posted 09 April 2017 - 04:33 pm
Ok so now big knob spins.... But doesn't seem to do oubt in terms of off and on. Haa joy. says clockwise for off... Nope. Says keep goin clockwise once circlip removed to remove knob... Nope. :-)
#10 wicklamulla
Posted 09 April 2017 - 06:25 pm
identical to our i'll tank PK,  even down to the Hammerite green paint finish. The smaller knob is to be PULLED out and released several toimes to purge air out of the 'oil level indicator tube' (if fitted),  there is a small ball that floats atop the oil within aforementioned level indicator tube.   This will then give 'he' an indication on how much i'll is stihl in the thank.   Oil pop oot and have a look now,  BRB.
#11 dapleb
  • 18,114 posts
Posted 09 April 2017 - 06:34 pm
Ta wicky,
Its was very easy to free once I knew attempted turn would not cause oil devastation, no undue force required. Lots of clag fell form behind valve.. I can only guess that summat has pooped in the mechanism as my linky dink shows the internal workings of valve, so if it aint unscrewing from thread when circlip removed ... The thread must no longer be functioning!!
Need to remove tank.... So this could get messy fast. Only other option if valve pooped is to fit blanking plug where feed pipe currently joins ... Gulp!!
Just so ya know wicky apparently knob should be removed once a year to copper grease thread!!
#12 wicklamulla
Posted 09 April 2017 - 06:37 pm
when i unscrew me big knob it seems to have a left hand thread and moves inwards to apparently isolate the oil thank.  Oi'm gunna try n' upload a pic from me mobile telling bone.
dare is also a sediment type of bowl at the base of this tap assembly which i assume needs cleaning out every few years or so.  Looks loike a boike carb float bowl.
#13 dapleb
  • 18,114 posts
Posted 09 April 2017 - 06:44 pm
Yeah clockwise turns oil off and if you remove circlip and keep goin clockwise removes the knob. My knob spins but dont go up or down thread. . . Cock it. :-) summat broked in the valve I guess.
Ta fur chicken.
#14 ramo
ramo
  • 1,177 posts
Posted 09 April 2017 - 07:50 pm
the knob above the white pipe just pulls out to allow fuel into the sight gauge so you can see the level of oil in the tank,it closes when you let go,
 the larger knob on the end is the isolation valve
#15 Studley Ramrod
  • 19,213 posts
Posted 09 April 2017 - 08:01 pm
I don't think it would go up and down thread chief.  Looks like the spindle would move to open or close the oilway, soooooo it could be working.  Also says the knob will continue spinning once it's closed.
#16 dapleb
  • 18,114 posts
Posted 10 April 2017 - 03:51 am
It says when fully open, back off 1/4 of a turn to protect threads... But it just continually spins in either direction!! It should stop at fully open but it just continually spins!
https://m.youtube.co...0&v=53Vy1qytciI
#17 Studley Ramrod
  • 19,213 posts
Posted 10 April 2017 - 09:38 am
Sounds like you have the same problem as shown in the vid Daps. :unsure2:
#18 dapleb
  • 18,114 posts
Posted 10 April 2017 - 11:22 am
I cannae see a problemo mentioned on the vid SR?
#19 dapleb
  • 18,114 posts
Posted 10 April 2017 - 12:10 pm
Phoned Atkinson who were ferry helpful.... Its fooked!!! Been left on full open which knacks the thread atwix outer knob and valve!! Cock badgers.
Wicky. Make sure yours is greased and backed off a quarter turn!
#20 Studley Ramrod
  • 19,213 posts
Posted 10 April 2017 - 02:33 pm
Strange, I clicked your link and ended up watching this vid, "Removing an oil valve handle"  by Sciencejunk
https://youtu.be/CJ8AqXk_Gpw
