One Downipipe Hotter Than Other
Posted 24 January 2011 - 01:06 pm
When I was running the engine up to temperature after the coolant change - at about 2000 rpm till the fan cut in - I noticed that the rh downpipe was glowing red. the lh downpipe was still hot, but not glowing to the same extent. I know the exhaust gets hot - but I was surprised to see one pipe this hot.
Is this normal ?
The bike runs OK, is on standard exhausts.
I did search through the forum for similar results - but couldn't find anything similar, so now I'm wondering if I've done something wrong
Posted 24 January 2011 - 01:32 pm
02 TDM 900, Silver. 85k miles
Posted 24 January 2011 - 01:59 pm
Try searching for 'glowing' Loadsa stuff.
Posted 24 January 2011 - 02:40 pm
Thanks for the search item - that does match what I'm seeing.
It's done about 24k miles so I'm hoping it's not the valves. ( I can't be bothered to take a look, I'd probably drop half my toolbox into the engine)
I did like the comment saying that it be because it's a 270 degree crank (crossplane?) - I did wonder if that might be so. The glow disappears quickly at idle.
I have seen turbo engines with whole manifolds etc glowing brightly - but they were producing serious power at the time.
The temperature guage behaves normally
Posted 24 January 2011 - 03:06 pm
Saw the same on my bike, but not just one, they where both glowing like chrismas lights. Bike behaves normally and every thing seems ok.
What can it be ?
Tdm 900 and Labrador.
Can it get any better.
Dont think so.
Posted 24 January 2011 - 03:51 pm
Posted 24 January 2011 - 04:06 pm
I've yet to run the diagnostics for this service, so I'll have a play and see if I can tune bu colour !
Thanks fopr the update.
Posted 24 January 2011 - 05:35 pm
What can it be ?
It's cos the exhaust is leaving the ports at around 1000 deg. C at 2000 rpm - kinda makes the pipes colourful as there's no wind to cool them......................
The left one has the ginormous oxygen sensor in it acting as a backpressure - wondering if that's why they're different - or the mixture is slightly different - wouldn't worry about it if it's going ok
