Putting In Rear Wheel Made Easier
12 replies to this topic
#1 leehenty
  • 5,085 posts
Posted 08 July 2020 - 10:54 am
Whilst putting Catsbums rear wheel in using brick and bits of wood to hold wheel up to line up everything, it occurred to me there must be a tool for this.
Abba stands make one called a wheel rizer.
I treated myself to one. I modified it slightly with washers to take the play out of the wheels and dome nutted the shaft.
Dog loves it he thinks it's for putting his toys on.
Edited by leehenty, 08 July 2020 - 10:55 am.
#2 catsbum
Posted 08 July 2020 - 03:39 pm
Yes we did struggle somewhat Lee.
Great solution and already "leemodified"
#3 dablik
  • 10,747 posts
Posted 08 July 2020 - 04:22 pm
More the front wheel i have a problem with cos of the speedo gubbins, rear just gets lifted and slotted in, but that looks handy..
#4 Andy25
Andy25
  • 335 posts
Posted 08 July 2020 - 05:40 pm
Nice one Lee
Bit cheeky on the price though ?
Would've thought about half that
Mind you if using fairly regular cost vs convenience
makes it worthwhile
#5 leehenty
  • 5,085 posts
Posted 08 July 2020 - 06:27 pm
It's a bit on the expensive side for what it is. Made of 1" square tube. It could easily be copied. Axel is 12mm rod turned down to 8mm each end and threaded. It made to work with the abba stand.
Front is fairly easy with the front lift attachment on the abba stand. I always use it as the two arms increase stability.
#6 MipeTDM
MipeTDM
  • 92 posts
Posted 08 July 2020 - 06:34 pm
Nice tool!
However can't help to show how I did it: just rolled the wheels into place :) :
#7 leehenty
  • 5,085 posts
Posted 08 July 2020 - 07:19 pm
That's one way of doing it
#8 gautrek
gautrek
  • 71 posts
Posted 09 July 2020 - 08:02 am
I just put the wheel on a piece of wood and use that to lift the wheel up.
Edited by gautrek, 09 July 2020 - 08:02 am.
#9 Bjørge
  • 1,791 posts
Posted 10 July 2020 - 11:12 am
+1
#10 TKH
Posted 10 July 2020 - 01:52 pm
+2
#11 dapleb
  • 18,114 posts
Posted 10 July 2020 - 03:58 pm
I just assumed everyone used their feet....they are height adjustable and everything! Maybe 9er is different
#12 Favs
  • 4,394 posts
Posted 10 July 2020 - 04:06 pm
+1
I use feet & 9er on mainstand is a POP. for me.
#13 drewpy
  • 1,758 posts
Posted 10 July 2020 - 04:18 pm
till your axle is out of reach  :lol:  been there
