Slight Petrol Smell
9 replies to this topic
#1 DaveW
DaveW
  • 39 posts
Posted 10 January 2021 - 03:15 pm
Went to do weekly start-up and check today. Slight smell of fuel. Took side panels off. No signs anywhere. Nothing on floor. Seems most noticeable from back of tank under seat, but still not strong. Tank is full for winter lay-up. Is this just out of breather pipe?
Where does breather come out? Is it the tube just in front of side-stand switch with a scrw-in plug?
Thanks again.
PS Remind me how to subscribe. I've had plenty of help from here and really must make a contribution!!!
#2 DaveW
DaveW
  • 39 posts
Posted 10 January 2021 - 03:56 pm
Forgot to say. 850 4TX
#3 DaveW
DaveW
  • 39 posts
Posted 10 January 2021 - 05:23 pm
I've now subscribed from my laptop. Worth every penny. Cheers
#4 Studley Ramrod
  • 17,955 posts
Posted 10 January 2021 - 08:06 pm
I can't remember where the breather pipe routes, other than it ends somewhere near the ground.  Any fuel on the floor ?
I'm assuming you have the electric fuel pump and no fuel tap ?
#5 DaveW
DaveW
  • 39 posts
Posted 10 January 2021 - 08:14 pm
Yep. No fuel tap. Nowt on floor.
#6 Studley Ramrod
  • 17,955 posts
Posted 10 January 2021 - 08:23 pm
Might be worth checking the fuel pipe connections on the tank perhaps ?  There's also a fuel tap there, which could be leaking.
#7 Snowbird
  • 489 posts
  • Location:Often on another planet, but mostly south Cambs.
Posted 10 January 2021 - 08:24 pm
Mine smells a bit of fuel when brimmed, probably just a bit of vapour from breather if no sign of leaks, a temperature or air pressure change could be the reason.
#8 drewpy
  • 1,235 posts
Posted 10 January 2021 - 10:09 pm
breather goes down the back of the tank, behind the engine between the swingarm
Mine's brimmed and can't smell anything
Mods; Oil pressure switch, neoprene rear inner mudguard, scottoiler, highway pegs,  fenda extenda, silicone airbox connectors, 15w fork oil, later clutch springs, LED lamps, Metmachex swingarm, Hagon Shock, Oxford heated grips, USB, 4 way fused accessory Bus, R6 electric fuel pump (5EB, kept seizing), 17" 3CV front wheel, Michellin R5 tyres, EXUP speedo.
#9 DaveW
DaveW
  • 39 posts
Posted 11 January 2021 - 12:08 am
Thanks gents.
#10 LewisBlackburn
LewisBlackburn
  • 1,716 posts
Posted 11 January 2021 - 03:08 pm
My 99 4tx always smelt of petrol, It was kept indoors and definitely wasnt leaking anywhere.  I'm sure a full rebuild might have sorted things but It didn't come about in the end.
