Valve Emulators
7 replies to this topic
#1 jono49
jono49
  • 1,183 posts
Posted 22 October 2014 - 09:45 pm
Has anyone fitted these to the forks of a niner yet? and which ones did you use from "Racetech" ?????
#2 dandywarhol
Posted 22 October 2014 - 09:56 pm
The same valves as for the 850 - FEGV S4301. I found the 0.85 springs too stiff so I reverted to the TDM springs
http://racetech.com/.../TDM900/2002-09
Edited by dandywarhol, 22 October 2014 - 09:58 pm.
#3 celticbiker
celticbiker
  • 1,726 posts
Posted 23 October 2014 - 12:44 am
You don't happen to have those .85 shooting lying around do you.
Was only thinking the other day that the front was a bit soft now I have the notion shock on the back.
#4 jono49
jono49
  • 1,183 posts
Posted 23 October 2014 - 05:58 am
Cheers Alan :good:
Oh and while I'm at it, did you change the weight of fork oil??
Edited by jono49, 23 October 2014 - 06:04 am.
#5 dandywarhol
Posted 23 October 2014 - 05:21 pm
Predictive text Celtic -doncha just luv it  ;) . Don't think I still have the springs - possibly Wicky got them but I'll have a look - there are some springs in the garage somewhere.
Did a mix of 10 and 15 to give 12.5 weight Jono - from memory it's a 2mm hole drilled in the damper tube for rebound. Curiously, I'm using 0.90 springs and 15 oil in the TRX.......................
Did a mix of 10 and 15 to give 12.5 weight Jono - from memory it's a 2mm hole drilled in the damper tube for rebound. Curiously, I'm using 0.90 springs and 15 oil in the TRX.......................that suits the Ohlins so you're probably on the right lines if you've stiffened up the rear unit CB
#6 jono49
jono49
  • 1,183 posts
Posted 23 October 2014 - 06:24 pm
This looks like the best deal going with free postage!
http://www.amazon.co...#productDetails
#7 TDrummer
TDrummer
  • 192 posts
Posted 24 October 2014 - 12:13 pm
Gents - new to the TDM (92)
Mine has cartridge forks?
are "niners" damper rod forks??
I have cartridge emulators in my KLR650 - they're great
thanks!
#8 dandywarhol
Posted 24 October 2014 - 05:16 pm
850 Mk2 and 900s have old fashioned (read cheap) damper rods.
Free postage within the States jono - got any friends/family over there?
