I bought a replacement copy Arai visor in light smoke off Fleabay for £23 and as winter is on the way I though I'd see what all the fuss is about with the Pinlock system, having never used or seen one up close. I bought a clear Pinlock insert for £10 then discovered that you also need the pins for the insert to slide into unless you have a Pinlock ready visor. Doh!!
Anyway, I got the pins, £3 Fleabay again, and tuned into youtube for the instruction vid. Out came the drill, 5mm bit, felt pen, hole starter thingy, block of wood to drill onto and then removed the visor for the operation.
Success, all went smoothly and the insert is now in and working fully.
In the words of Tony the Tiger, THEY'RE GREAT!!
A comprehensive thumbs up and if you are considering doing this mod, don't hesitate, it's relatively straightforward, it's relatively cheap, and it works.
Photo-0184 (1).jpg 38.78KB 0 downloads
Edited by tediumwannabe, 07 October 2015 - 04:04 pm.
