Suspension Linkage Parts
4 replies to this topic
#1 leehenty
  • 5,085 posts
Posted 26 January 2020 - 02:23 pm
AliG wanted to know the parts needed to service the linkage so here it is in case it is of use to others.
Please note some sort of press tool will be needed to press these out with. I made someone on here a  press tool.
It might have been Picard but I can't remember now who it was.
If one is needed just let me know, I can post it for a lend.
TDM900 Rear suspension linkage parts list.
4 off TA1715Z – IKO
2 off TA1720Z – IKO
or
http://shop.marksman...rings-536-c.asp
6 off 17x24x3 oils seals. (marksman)
http://shop.marksman...4x3-28209-p.asp
Any Yamaha Dealer
2 off 90387 - 126Y1 Collar (Yamaha)
1 off 90387 - 1012B Collar (Yamaha)
1 off 90387 - 127W0 Collar (Yamaha)
Edited by leehenty, 26 January 2020 - 02:44 pm.
#2 wicklamulla
Posted 26 January 2020 - 02:25 pm
gold dust info.  good man for sharing it.
#3 leehenty
  • 5,085 posts
Posted 26 January 2020 - 02:39 pm
It had a long thread on here in the past. I keep all this info on dropbox.
Another very handy reference. All sizes of steering head bearings for bikes. Handy if you want to go taper roller.
https://www.dropbox....l 2011.pdf?dl=0
Edited by leehenty, 26 January 2020 - 02:42 pm.
#4 Norwegian
Norwegian
  • 162 posts
Posted 26 January 2020 - 07:58 pm
#leehenty, brilliant link on the tapers, thanks! I may want to do that.
Quick question - I see that bearings exist in abundance online, no problem. But what about the dust covers and shims listed - necessary (probably)? Source?
#5 leehenty
  • 5,085 posts
Posted 26 January 2020 - 08:26 pm
tdm kit of taper bearings includes these
