92 Tdm 850
Posted 13 January 2018 - 04:53 am
Enjoy the day
Posted 13 January 2018 - 10:18 am
Welcome to the club. When composing a post, click on the 'More Reply Options' you'll then see the option to Choose Files below the text box.
Posted 20 January 2018 - 04:10 pm
Posted 20 January 2018 - 07:27 pm
Will be interesting to see pic but am unaware of any limited edition or collectors version of mk1.
Posted 20 January 2018 - 08:04 pm
Good day every one. Tony Laranja from South Africa. I bought a 92 tdm 850 but I can't find another one like mine to do cross reference.Just to find out if it's a limited edition or rare collectors as that alot of guys tells me it is. An what the ZAR value perhaps could be.
Enjoy the day
Edited by TonyLaranja, 20 January 2018 - 08:10 pm.
Posted 20 January 2018 - 08:17 pm
Not many have been altered to have single arm swinger.
No idea of value over there. Over here I would take an uneducated guess at 700quid.
Posted 20 January 2018 - 08:22 pm
Posted 20 January 2018 - 08:43 pm
Looks like a VFR 750/800 has been applied somewhere along the line?
Here's another, different, 850
http://suprememotos....ront-wheel.html
Edited by Favs, 21 January 2018 - 07:12 am.
Posted 20 January 2018 - 09:29 pm
As well as the Honda swing arm being installed it also looks like the wrong front forks might have been slung in too, the petrol tank should not slope forwards at that angle (the top of the fuel tank & filler cap should be level) unless the forks are poking through the top yolk by 3 inches ! or poss due to the wrong length rear shock being installed jacking the back end up way to high, by the look of some of the photos it's not the original rear shock, as for "brought new from the showroom like that" perhaps one of the Yamaha dealers mechanics had a play to make a "special edition" but deffo not a Yamaha offering, might be wrong tho'.
Edited by Gdogg, 20 January 2018 - 09:34 pm.
Posted 21 January 2018 - 09:25 am
Edited by Swarf, 21 January 2018 - 09:48 am.
Posted 21 January 2018 - 12:28 pm
Dont like what i presume is the rear brake line hanging about somewhat, surely it should be fixed a bit more securely ??
Edited by dablik, 21 January 2018 - 12:31 pm.
Posted 21 January 2018 - 12:47 pm
Front wheel is a 17 an back wheel 18
Posted 21 January 2018 - 02:42 pm
Yes it's the rear brake line. An it secure. I did make sure about it. Purchased a proper brake line holding brake. There is no way that the line can get damaged by either the chain or wheel it self. But thanks to the input.
Ah that's your problem, the wheels are back to front certainly different though
Posted 21 January 2018 - 03:08 pm
#16
Posted 21 January 2018 - 06:40 pm
Reckon you might be running out of fuel pretty quickly with the tank at that angle.
#17
Posted 21 January 2018 - 07:01 pm
#18
Posted 21 January 2018 - 07:28 pm
Because you get less fuel out from the outlet when the tank is at an angle like that. I've rested my tank at a similar angle when it was off the bike and drained it off, had to tip the tank level to get more fuel out of it.
#19
Posted 22 January 2018 - 08:40 pm
It certainly looks a little different. Not in a bad way. A few franchised dealers over here sometimes through their owners or head mechanics wishes make the bike they believe the manufacturer should have. Triumph dealers doing specials for instance. They are not neccessarily backed, endorsed or funded by the manufacturer and in the cases i have seen are also not covered by the standard warranties. This is not a critisism so please don't take it that way but you'd have to ask yourself if the mods done actually benefit the bike and if they do then why didn't Yamaha do the same. Cost maybe who knows.
As to value thats so personal to any potential buyer. If I didnt know the TDM brand your bike looks like a funky single sided swingarm older bike. If, like the majority of readers on here they do know the TDM brand, they may want a standard, tried and tested bike. The value over here is definately in unmolested original bikes.
All that being said, it looks like a fun bike and to any yamaha enthusiasts would definately be a head turner/talking point. enjoy the bike.
#20
Posted 23 January 2018 - 06:18 am
Only problem I experience now is the following.
I replaced the rectifier an stator but it's like the battery is getting drained after about 15km drive. It starts to like misfire an then just goes dead. The battery then sound flat an refuse to start up again. After standing to about 30min or so the the bike starts again. Almost like there is a build in Ghost charger hidden so well in it that it's impossible to find. Can it be a bad battery cause that's the only thing I didn't replace. I took readings with multi meter before start up an ignition off 12.43v. Ignition on before start up 12.11v. Startup drop to 11.23v an rises to 12.58v while idling. Lifting refs to 4k the voltage stays between 12.45v an 12.59v.
Any ideas or tips please.
