Water Pump And More....
Pump sump
19 replies to this topic
#1 MikeyMex
MikeyMex
  • 27 posts
  • Location:Jalisco the birthplace of Tequila and Mariachi
Posted 16 January 2018 - 10:55 pm
LOL not!
Just had to take out my water pump, all good, then dropped the washer in the sump, ok so a bit more work.
All good until I find the headers rotten, managed to move them, couldn't separate the headers from the collector box either, so took off the whole exhaust complete, easily done as the centre bolt behind the sprocket had never been screwed in properly and was hanging off.
Oil smelt a bit petrolly?  I then got nearly 9 litres of liquid out of the bike that only holds 6 litres in total, now starting to get worried.
Looks like piston rings in the bottom of the sump. I found the washer from the water pump though LMFAO what can I do but laugh.  The guy I bought it from obviously used a shade tree mechanic as there is as much liquid gasket in the sump as metal parts.
DT50M '78, KH100EX '86, RD350LC (many), RD250LC '83, VF400F '83,  Z200 '77, RD400 '76, LTD450 '88, R45 '80, R100RS '82, GSX750SE KATANA '84, FJ1200 '92, GPZ750A1 '84, R100CS '78, (then came 17 years in Mexico and hundreds of Chinese scooters later.... I finally get another real bike) TDM850 MK1 '91 and a KLR 650 '88 for the rough stuff.
#2 James
James
  • 570 posts
Posted 16 January 2018 - 11:12 pm
You ain’t having a lot of luck with that bike Mikey. Still, it should be good once you’re through with it. Good luck!
84 Honda XL600R  :)
04 TDM900  :good:
21 KTM 790 Adventure  ;)
#3 MikeyMex
MikeyMex
  • 27 posts
Posted 17 January 2018 - 12:01 am
Thank you Jim, you're not wrong!
Fortunately I don't have to work everyday anymore so I can spend more time doing this and making her right.
If this has happened back in the UK I would have just given her away and got another ride, I had to do 100 miles a day to work and back, not any more!
#4 fixitsan
  • 4,676 posts
Posted 17 January 2018 - 08:20 am
My 850 was the same in the bottom, even down to the bits of piston ring. Although,
If there is that much sealer floating around in the bottom then you better check the strainer which hangs down into it too, mine was a screen made of of three types of sealer.
The extra 'oil' could well be petrol which drained down fromt he carbs while the bike was stationary
#5 drewpy
  • 1,758 posts
Posted 17 January 2018 - 12:29 pm
need carbs checking as float needles letting fuel in. I assume you have carbs on this bike?
#6 Studley Ramrod
  • 19,214 posts
Posted 17 January 2018 - 03:15 pm
Blimey !
#7 MikeyMex
MikeyMex
  • 27 posts
Posted 12 February 2018 - 06:04 pm
I haven't been home for a while, just got back and checked this out.   Thank you Fixitsan, good point I will check that out, Drewpy I tink you may be correct, the oil smelt a lot like petrol.  I have the carbs in my grimy little hands now, justy about to take off the valve cover and head.
Cheers all I will let you know what I find.
#8 MikeyMex
MikeyMex
  • 27 posts
Posted 20 February 2018 - 10:54 pm
LMFAO,
Finally got her apart, pistons, rings valves and seats all in good working order, now just to find a new water pump and gaskets and she'll be back on the road.
it appears who or whatever (neanderthal) worked on her before never flushed out the remains of the last ring job before putting her back together.
Mikey, things are looking up :)
#9 MikeyMex
MikeyMex
  • 27 posts
Posted 18 July 2018 - 02:09 pm
She be running, a bit rough but she alive!   Am very pleased with finally getting her going again, just have to sort out the carburation.  Half the Cali spec stuff was there, now I have cleaned her up I gotta work out which hoses make her sweet, I think I am missing a vacuum or a plug somewhere :)
Mikey
#10 MikeyMex
MikeyMex
  • 27 posts
Posted 18 July 2018 - 05:16 pm
LMFAO, after taking the gas tank off maybe four times I finally realised DUH, hang the f''ker on the wall and give her an IV, wow how much easier was that then?
She's running but still a bit dodgy in the midrange, idle goes up and down a little and throttle return/deceleration is slower than I expected.  Gonna drain the rad later and just double check my cam chain rebuild and make sure it's all where it's supposed to be.
Anyone know what to expect running wise if she's just a toof owt?
Mikey
#11 MikeyMex
MikeyMex
  • 27 posts
Posted 18 July 2018 - 05:27 pm
Gasoline IV installed...
#12 fixitsan
  • 4,676 posts
Posted 18 July 2018 - 06:37 pm
With a tooth out it would probably be rubbish all over the rev range, but i haven't experienced it...nothing wrong with taking the cover off and checking it
#13 MikeyMex
MikeyMex
  • 27 posts
Posted 19 July 2018 - 11:18 pm
Ok so here are the photos, I took the cover back of just to double check, she looks good to me, all lines appear in the right places, also attached a bonus picture of the diaphragms I just replaced, I was surprised she was running at all when I bought her.
#14 fixitsan
  • 4,676 posts
Posted 20 July 2018 - 07:21 am
Certainly looks close enough to me. One tooth either way would look a lot worse
#15 MikeyMex
MikeyMex
  • 27 posts
Posted 20 July 2018 - 04:34 pm
Thanks Fixitsan, I thought it was good, just helps me a lot with the second opinion.  The inlet does seem to be a tad out, but I think that's just chain wear.  Also inside the carbs I found a small hole on the needle valve assembly post, where the gas is monitored by the valve and sure enough the one bowl was full of gas because of this.  Now I have sealed it back up so the float should work (no more flooding) maybe I'll have a great running motor.
:)  All is good... Thanks again
Mikey
#16 MikeyMex
MikeyMex
  • 27 posts
Posted 25 July 2018 - 07:30 pm
All back together and running fairly smoothly, just got a little idle needs adjusting, rest of the rev range, water pump and pistons all good, will be going out for  ride later today.  Very, very happy....
Mike
#17 MikeyMex
MikeyMex
  • 27 posts
Posted 26 January 2020 - 09:57 pm
Update, she's all running, starts and idles well, runs great until she gets warmed up then runs like a complete dog through the entire rev range. Have rebuilt carbs, new choke assemblies, whilst waiting to overcome my health problems the calipers welded themselves closed on the front disc, now have r6 front calipers, great improvement over the originals. Any ideas why she runs bad when warm, I haven't managed to ride far enough for her to get really warm.
#18 wicklamulla
Posted 26 January 2020 - 11:03 pm
  how ya Mikey,  i wonder if the ignition coil is breaking down or the valve clearances are out of spec?
#19 Bjørge
  • 1,792 posts
Posted 27 January 2020 - 07:43 am
Worn emulsion tubes cause rich mixture, easy start when cold but rubbish when hot. Also causing excessive consumption. Might be worth a check ?
#20 Studley Ramrod
  • 19,214 posts
Posted 27 January 2020 - 02:00 pm
Running worse/bogging down the warmer it gets is a symptom of richness, could be wrong main jets or needle jets setting too rich. Factory Pro needle jets can also produce a similar problem.
Surging is a symptom of running too lean.
Have you fine tuned the carbs ?  Adjusted the carb balance.
Also, sometimes the thermostat housing starts leaking when the engine has warmed up, causing coolant to flood the spark plugs and causes rough running.  Only happens when engine is warmed up though.
