Posted 25 May 2015 - 09:24 am
Some moons ago Celticbiker very kindly got me some alloy side plates cut out for a beam engine model.
The master engineer has been burning the midnight oils and has got this far. Just the cylinder valve plate and outer eccentric to go. He made the flywheel yesterday with a bit of a lash up on my dividing head. We owe celtic a few
Edited by leehenty, 25 May 2015 - 09:31 am.
