Loose Clutch
Posted 23 June 2006 - 07:20 am
comes in a bit. but there seems to be alot of movement on the actual lever (up and down) sometimes think the bloody things gonna come off. Or are all TDMs the same
Posted 23 June 2006 - 07:28 am
Posted 23 June 2006 - 08:09 am
Wasss one of dem ??
Posted 23 June 2006 - 09:10 am
Its gonna cost ya but is worth the expense. I think Dandywarhol knows how to contact him.
Boop
Posted 23 June 2006 - 09:12 am
But I can do adding up, me.
Seriously, I guess if you can't find one of the exact thickness you need, get one slightly too think and then gently file file down the lever until you get a smooth fit without too much friction. Then slap it back together with lashings of ginger beer^H^H^H^H^H^H^H^H^H moly grease.
Posted 23 June 2006 - 09:33 am
you do realise your talking to someone who struggles to figure out how to oil the chain, and your asking me to use a file??? ill have to open the other halfs make up bag . she keeps plenty of files in there .
Posted 23 June 2006 - 09:49 am
Edited by andyj, 23 June 2006 - 09:49 am.
Posted 23 June 2006 - 10:33 am
its only a year old , TDM 900, me , non of this 850 lark for me anymore.
its probably just me being paranoid
Posted 23 June 2006 - 10:53 pm
I'm having the same clutch lever concerns (20 month old bike, 6500 miles). Had a Honda Transalp previously - same problem so fitted a shim or two. Metal ain't what it used to be back in my hippy days - exhausts were triple-walled then, too, and stayed silver-shiny....
Posted 24 June 2006 - 06:16 am
I would be very wary of anything that has been retained by the Eccles ring
Posted 24 June 2006 - 08:02 am
its nice to know im not the only one that can lower the tone...well done bob
Posted 24 June 2006 - 03:51 pm
If you're gonna change the lever it may well be worth changing the pivot bolt too. Although the lever is made of soft ally there may be a bronze bush in it which may wear the pivot bolt too. If the bolt is worn it will be easy to see when removed.
Don't want to offend anyone by contradicting a fellow Carpedian but I find ordinary yellow grease is thicker for external use .
Moly grease is thin engine assembly paste and will wash away.
Mind you anything is better than nothing.
Edited by Jez, 24 June 2006 - 03:52 pm.
