I had to replace the stator last March on my 2003 900 but didn't replace the R/R.All went well until last week and again the stator has gone short circuit.My problem now is,having re-assembled everything and replaced the stator,all is well again,14vdc etc.I purchased a R/R when the stator first burned out but didn't use it due mounting issues.There is no evidence of any smell or brittle connections etc on the original R/R but I cannot say with certaintity if the original is perfect or not!Do R/R ever go short circuit intermittently resulting in over current on the stator windings?To mount the Electrex unit will be close to a disaster due heatsink probelms etc due to it's higher operating temperature compared to the original MOSFET type unit.
Any comment welcome!
Regulator Rectifier
Started by
Gandy
, Jul 17 2010 12:49 pm
7 replies to this topic
Posted 17 July 2010 - 12:49 pm
#2 Guest_mattspeedtriple_*
Posted 17 July 2010 - 01:58 pm
Yup, reg/rec`s can go open circuit when hot. If you`ve now burnt out a second stator then get the Electrex R&R fitted asap as they`re better quality than standard units and hopefully you won`t have to pay out again for yet another stator. Remember that you can always extend wires to allow you to fit the new R&R where ever you want and allow it to get the best air flow it can.
#3 Guest_celticbiker_*
Posted 17 July 2010 - 02:05 pm
Are you buying new stators or having them rewound?
When mine went I had it rewound and when ity came back it had been done with much heavier guage wire.
Posted 17 July 2010 - 03:02 pm
QUOTE(mattspeedtriple @ Sat 17th Jul 2010, 02:58 PM) <{POST_SNAPBACK}>
But do they ever go short circuit thus causing big current flow through the stator windings?QUOTE(celticbiker @ Sat 17th Jul 2010, 03:05 PM) <{POST_SNAPBACK}>
Are you buying new stators or having them rewound?When mine went I had it rewound and when ity came back it had been done with much heavier guage wire.
Both were off the shelf,not re-wound units.
#5 Guest_mattspeedtriple_*
Posted 17 July 2010 - 03:09 pm
Yup, they can also go short circuit and cause the stator to overload. SV650`s suffer from this problem as the R&R`s will go duff when hot but read fine when cool and then take out the stator. There`s really only two things in a charging system so if you have the new R&R then fit it as stator is the other which your already replacing anyway.
Edited by mattspeedtriple, 17 July 2010 - 03:10 pm.
Posted 17 July 2010 - 03:18 pm
QUOTE(mattspeedtriple @ Sat 17th Jul 2010, 04:09 PM) <{POST_SNAPBACK}>
Matt.mind made up,am putting in the Electrex unit this evening no matter how awkward the job may be!
#7 Guest_celticbiker_*
Posted 17 July 2010 - 03:43 pm
QUOTE(Gandy @ Sat 17th Jul 2010, 04:02 PM) <{POST_SNAPBACK}>
Blood ell mate, I know how much they are, I was quoted £600 from the dealers.
I got mine rewound in Devon (UK) for £55 and had it back in 3 days
Contact details for rewind should you need it
See here for my stator story
And here for a fault finding flow chart.
Obviously you know what you're doing electrically but it might help identify a reg/rec fault
Edited by celticbiker, 17 July 2010 - 03:56 pm.
#8 Guest_LDRider_*
Posted 17 July 2010 - 05:11 pm
Don't know about the 900s, but the R/R on MK1s is a weak link in the system. I fried 2 before I replaced it w/ the much higher capacity R98 unit.
