'ere's a wiring diagram - > https://www.flickr.c...eposted-public/
For those who will receive a prototype shortly, please drop me a line if anything needs clarification, I'm happy to help and appreciate you are helping me by trying out this doohickey
The prototypes have basic waterproofing, they would probably leak a little bit if submerged in water but hidden behind a body panel they will be fine. You can fit the control box using cable ties through the box's edge slots and probably also double sided tape should work in a clean and dry location. The light sensor on my bike is trapped between the inner cowl and the side panel, facing upwards. I've included a 6way connector and terminals, which is completely optional to use, but just in case someone felt like making it removable i included it. I have no idea about MOT testing and would normally disconnect this sort of device, or simply remove the fuse. The 12V supply should be fused and ought to be switched with the ignition.
The installation ought to be straightforward, the only question might be about the horn wiring. I have written the code to automatically detect whether the horn is wired for active low or active switching. you should fit the pink wire to the side of the horn which is switched. On a 900 one side of the horn has a permanent 12V supply, because it is switched low on the other terminal, it is this other switched terminal which should be used. But you can not damage the unit if you get it wrong the first time, so a trial and error approach works. Just make sure you turn the ignition off in between attempts.
When you sound the horn the DRL's will flash rapidly for a couple of seconds.
When you turn on the high beam the DRL's will be set to high brightness regardless of the ambient light level
There is some intended flickering/glimmering at about 14Hz frequency of the DRL's, which will probably only be noticeable if you use basic LED DRL's . If your DRL's have a wide input voltage range, such as 12-80V (like mine have) then the internal power supply within the case of the DRL will smooth out the glimmering , however all functions including the automatic dimming for night use will still work as intended.
For a simple quick check you only need to connect the red, green and black wires, the pink and blue wires can safely be left 'floating'
The only DRL's which are problematic are those with built in strobe functions, which you have to cycle through power on/power off cycles to get them into the mode you prefer.The glimmering effect of the controller confuses those DRL:'s internal controller.
Some DRL's have three wires, red, yellow and black. Whenever the yellow wire is switched to the red wire the DRLs step through their programmed modes (usually at leats one flashing routine and one brightness setting. I guess you can still use these. Just set them to their brightest steady output and then connect the yellow wire to the black wire to keep the unit locked in it's current mode.
The unit uses barely any power, and the internal MosFet transistor switch is rated for up to 10Amps of current. There is no heat management involved though so 10A of led DRL's would probably cause it to get pretty warm, but bearing in mind that a single DRL is unlikely to draw more than 1Amp I can't see this being a problem, but then this is what I need to find out too ! In my tests the unit didn't get warm even at 5Amps.
Edited by fixitsan, 24 March 2018 - 12:01 pm.
