My theory is that the vac pump gets a vac lock when left for a while without starting. It can also be a problem if you're switching over to reserve and don't make it before the engine stalls, can take ages to get the fuel through again.
This would be one good reason for an electric pump! I've fitted one for my MkI, and after draining both bowls it started right off as float chambers are filled once you switch ignition to 'on'. just wait for the noise to stop
