Need To Adjust Fuel When Installed Electric Pump?
Posted 07 November 2018 - 02:57 pm
At first (new float valves, vacuum pump) levels were too low, caused by a stiffer spring, methinks.
Also, what is the smallest off-adjustment level you have experienced to affect running, or the other way - largest off-adjustment that did not affect running?
Posted 07 November 2018 - 08:41 pm
Shouldn't really matter if they only look to be barely open so long as they're filling the carbs. I'd expect them to be closer due to leccy pump in place of vac wan.
Difficult to know really, unless you've actually run the bike at many different fuel level settings and recorded them all. Given that there's only 1mm to play with between min and max fuel level, I would imagine it's fairly critical. Maybe a couple of mm ?
Posted 08 November 2018 - 06:21 pm
Adjusting the fuel level accurately is not easy, especially when the 1mm range is to be hit. The capillary effect makes it all but a straight line....
I'll give it a try tomorrow!
Posted 10 November 2018 - 01:49 pm
I start wondering if it's the measuring procedure...what's the actual fuel level in bowl supposed to be when running?
One question I ask is what's happening when you open the drain screw to let fuel flow into the the clear tube to measure? Is there still pressure to fill bowl, or is internal fuel level sinking? If the latter is the case, then length and inner diameter of tube will be crucial...
Posted 10 November 2018 - 02:42 pm
Fuel level when running should be the same. Should be enough pressure to keep fuel bowl full, assuming your fuel supply is higher than the carbs. Worth making sure the drain screws are opened a good few turns or you might get a false reading.
Posted 10 November 2018 - 06:29 pm
Afraid I just have to try without measuring. But it's such a hassle!
Posted 17 November 2018 - 11:26 am
Bit the bullet, and ordered a 2nd hand FZR fuel pump, starting all over....
Posted 01 May 2020 - 09:14 am
Any guesses out there? Will leccy pamp affect fuel levels?
...should mention I've installed new OEM valves...
Edited by Bjørge, 01 May 2020 - 09:15 am.
Posted 01 May 2020 - 10:22 am
Well, finally got to pick up this work after selling the 9er. Carbs on bench, reset level to ~0 by straightening tangs. Still on gravity feed. Todays project is hooking up the fzr pump to see effect on fuel level before trying to hit the sweet spot.
when I had a fuel pump , i lowered the float by 1mm after installing new float needles
Posted 01 May 2020 - 12:00 pm
I just tried it, and the pump doesn't seem to affect level. That is, I found out auxilary fuel tank affected fuel level below a certain height. After raising it, there was no rise in level when I switched pump on.
Very happy with that, now I just need to get level up some 5 and 7mm.
Btw, this is a ~1990 fzr600 pump, and it is very much less noisy than the chinese crap one I tried earlier😎
Also, fuel lines seem to fit, being 8mm.
Posted 01 May 2020 - 02:23 pm
Starting over 😎
Posted 01 May 2020 - 03:11 pm
Didn't think of what angle carburetter sits on bike...
Starting over
that helps
Posted 01 May 2020 - 03:54 pm
Looking forward to install tomorrow and maybe hear the old cow running again 😎
