Posted 24 June 2020 - 08:56 pm
1.25 pitch, only Suzuki on some models used 1.0 pitch. Don't screw it in, it will jam tight, then shear off. Happened to younger brother leaving a difficult job extracting broken bit.
Edited by leehenty, 24 June 2020 - 08:59 pm.
