Dabbers, dappers and Studders Shim Jibber Jabber
Posted 04 September 2012 - 10:01 pm
The manual states " Valve clearance (cold) ".......Intake = 0.15~0.20 and Exhaust= 0.23~0,28,, can anyone confirm please,, TIA
Posted 04 September 2012 - 10:52 pm
Yup, them's the right clearances bod.
Posted 05 September 2012 - 09:53 am
Posted 10 September 2012 - 01:43 pm
Posted 10 September 2012 - 03:02 pm
Goo wan lad !
Posted 10 September 2012 - 06:50 pm
Intake = 0.15~0.20 and Exhaust= 0.23~0,28 per the manual,,,,, heres mine
Oh the one i have put a cross on,, when measured the 2nd time was 0.11 summit wrong there....
So the exhaust on cylinder 2 are only just in spec,, exhaust on cylinder one look dandy,,,but fook me thas a lot of shims to change on the Inlet side,,,
Edited by dablik, 10 September 2012 - 07:08 pm.
Posted 10 September 2012 - 08:01 pm
Soooooo, you gonna change 5 inlet and 2 exhaust shims then Cliff ?
Posted 10 September 2012 - 08:18 pm
Okay measured the clearances again today and heres a piccie with shim sizes,,, ermmm need to try work out what to replace with now,,,
Guess i should of left the two exhaust on cyl 1 in there..
This looks like the replacement sizes i need,,, replacements are on top and underlined..
I can re-use a 185,, but need a 180,, 3 x 185 and 195...... well i think,,, would someone be kind enough to check please,,, never done these before and would'nt like to screw up now
BTW... JBX's site is up and running,,,, i checked these sizes in the Manual and then on JBX'x guide..
I have 1x 185 and 1x 195,, i also have a 184, can i use this instead of a 185 for the inlet valve which measure 0.13 maybe !!!! which would leave me needing 1 x 185, 1x 195..
Dappers
Edited by dablik, 11 September 2012 - 04:15 pm.
Posted 11 September 2012 - 06:13 pm
Reet !
You can re-use the 192 instead of the 195 on no.2 middle inlet.
Yes, you can use the 184.
I think you'll still need a 180 and a 185.
You cudda helped by listing all of the spare shim sizes you borrowed of Charlie.
Posted 11 September 2012 - 06:49 pm
I have 185 and 194. The nice thing bout the stock of orig shims is that they go up in increments of one....so if you lettuce snow exact sizes oi moight ave em.
Posted 11 September 2012 - 07:25 pm
Okay dappers,,just back from borrowing a small torque wrench ready for the job,,, will go check thanks
Posted 11 September 2012 - 07:30 pm
Reet !
Sorry chap,,, here goes...195,190,191,188,185,184,175,175
Posted 11 September 2012 - 08:52 pm
Edited by dablik, 11 September 2012 - 09:06 pm.
Posted 11 September 2012 - 09:27 pm
No can do matey, you'll need to buy a 180 bod.
Still, on the plus side, you've saved having to buy 8 new shims. Yammy wans are about £7-£8 each.
There used to be a shim seller on ebay, sold 9.48mm Hotcams shims fer around £4.
Posted 11 September 2012 - 09:34 pm
Okay cheers m8,,, one last thing,, is it worth changing Ex cyl 1,, valve clearance of 25 with a 184,,,,,,(be a tad more even with the rest of Ex valves ) this means getting a 185 and a 184 and buying a 180 of eboo..
Edited by dablik, 11 September 2012 - 09:54 pm.
#16
Posted 11 September 2012 - 09:57 pm
Inlet cyl 1 middle with valve clearance of 16 has shim 195 (in spec) can change with 191 to bring it up to 20 clearance,,,more on pa with the rest!!!!!
Edited by dablik, 11 September 2012 - 09:59 pm.
#17
Posted 11 September 2012 - 09:58 pm
EDIT: Go to bed ! lol
Inlet cyl 1 middle with valve clearance of 16 has shim 195 (in spec) can change with 191 to bring it up to 19 clearance,,,more on pa with the rest!!!!!
Yes.
#18
Posted 12 September 2012 - 07:45 am
#19
Posted 12 September 2012 - 09:51 am
Dappers i'm going to double check all this in a minute to be sure,, thanks for getting back..
pm sent..
Edited by dablik, 12 September 2012 - 10:15 am.
#20
Posted 12 September 2012 - 10:16 am
http://www.ebay.co.u...=item35bb55bc16
