Finally It's Here.
14 replies to this topic
#1 leehenty
  • 5,090 posts
Posted 13 February 2020 - 05:39 pm
I have been waiting for this D1:3 camlock, ER40 collet chuck since last June. Fits perfectly and runs true within less than 0.01mm, so low even my fancy clock can just see it.
Like a dog with two tails now.
#2 Snowbird
  • 1,359 posts
Posted 13 February 2020 - 06:03 pm
More TDM bling coming soon then?
#3 ChrisG
  • 8,276 posts
Posted 13 February 2020 - 06:43 pm
Just as well you retired so you've got time to play  :lol:
#4 leehenty
  • 5,090 posts
Posted 13 February 2020 - 07:58 pm
The master engineer made one out of mild steel as he got tired of waiting, which I've been using, but it's started to wear out being a bit soft.
This one is hardened and ground. Not only TDM bling, but Royal Enfield bling too.  :)
So I'm all set up now, until I shuffle off.
#5 dablik
  • 10,757 posts
Posted 13 February 2020 - 10:19 pm
Lovley, what you making Brass bits for Lee.
#6 wicklamulla
Posted 13 February 2020 - 11:09 pm
monkey's balls.
#7 leehenty
  • 5,090 posts
Posted 14 February 2020 - 09:06 am
Brass pipe plug for Lister CS/6,hex head will be milled on dividing head as owner wants it to be Whitworth sized.
monkey's balls.
Actually I do have a Ball turner
#8 dablik
  • 10,757 posts
Posted 14 February 2020 - 01:01 pm
Go easy with it..
#9 tr7dan
tr7dan
  • 116 posts
Posted 15 February 2020 - 09:41 am
Accurate to 0.01mm you say ? Sorry, that's never gonna work on a Enfield.....
:lol:
#10 leehenty
  • 5,090 posts
Posted 15 February 2020 - 08:54 pm
Take the RE wheel spacers for example supposed to be bored 17.00 mm. 17.36 one end 17.64 the other and ends not parallel to each other and the bore skewed not centred. Made my own.
Quite a few bits have been binned and I got a bucket of substandard nuts and bolts, primary and drive chains, bearings etc, the list is long, but it's been fun.
#11 Snowbird
  • 1,359 posts
Posted 16 February 2020 - 01:22 am
I work for an aero engine company ( old lawnmower tech not jets) and if a crankshaft is below limits we do a .003" undersize in a lathe with emery tape, we used to do .006" the same way but now they are supposed to be sent away for that one and re-nitrided, the reason being most in the game have equipment to vauge to grind any less, it's a soul destroying job having to check for ovality and paralel as you go with a micrometer.
I one had to do a 6 pot crank on the ends because of a few small corrosion pits from a very good standard size, two days later I had lost the will to live, never regained the will to live till I got a TDM.
#12 drewpy
  • 1,758 posts
Posted 16 February 2020 - 03:32 pm
Cool, more things to make
#13 leehenty
  • 5,090 posts
Posted 16 February 2020 - 05:55 pm
I had a Honda VFR apart once. They now use special lobed screws like a zip bolt which kind of cuts it's own thread, no proper tapped threads at all. It was hell taking it to bits.
So an M6 screw has a M4 shank. Moose sheared heads of every other one trying to put them back. The Helicoil stock got depleted that day.
Edited by leehenty, 16 February 2020 - 05:55 pm.
#14 dablik
  • 10,757 posts
Posted 16 February 2020 - 09:23 pm
Oh he kept that part quiet he did, about shearing the bolts :lol:
#15 leehenty
  • 5,090 posts
Posted 18 February 2020 - 04:49 pm
It was ok he left with lots more stainless than he arrived with, had to do all of the cover bolts in the end or it would have looned wrong.
