i have managed to get my bike running again after several issues but i have noticed that the oil is not circulating bk into the oil tank so oil light is on permanently , i have checked the pump and all works with the engine as it should , i have chaecked oil pipes for blockages and they are good , so is there anything else i may have overlooked ?
Posted 16 January 2020 - 02:41 pm
Posted 16 January 2020 - 02:59 pm
Glad to hear you're running.
Which tank are you looking at, there are 2. Assume you have enough oil in?
Posted 16 January 2020 - 03:13 pm
Ok Ferks how much oil have ya put in the enjun? is the problem you are now having on the original enjun or the replacement ya bought last week? I tink ya may have either too little oil in there or an electrical fault?
Posted 16 January 2020 - 03:48 pm
Posted 16 January 2020 - 04:12 pm
Oil filter upside down?
that is not unknown apparently, even when the right way up ya need to be careful not to crush or deform the filter. there have been a few cases of seizure due to this.
Posted 16 January 2020 - 04:27 pm
Correct me if I am wrong but none of the 850 nor 900 models have an oil pressure switch as standard, its an oil level sensor on the 900 maybe the Mk2 850 has the same system, the 3vd has nowt so futuristic
Posted 16 January 2020 - 04:51 pm
Posted 16 January 2020 - 08:11 pm
There's a 10mm bolt on the left hand barrel that you're supposed to undo and check for oil pressure after changing oil and filters. Maybe undo that and see how strong it flows, if any.
Posted 16 January 2020 - 08:19 pm
MK1 has oil pressure sensor..... Tek ooot the oil gallery bolt and ewe will get a sense of if there be any oil pressure or not. :0)
yew 2 are on the same hymn sheet.
Posted 16 January 2020 - 09:00 pm
A long shot but it might be a blocked oil strainer, the strainer is located just above the sump so you have to remove the sump to get to it.
Happened to me with my mk2a 850, although it was self inflicted. I managed to drop some cardboard into the engine.
Posted 18 January 2020 - 12:27 pm
ok cheers guys will have a look at it and see whats what
Posted 29 January 2020 - 05:11 pm
ok heres an update got the bike sorted runs lovely now like a new bike , found out why oil wasnt recirculating bk to the tank ,think the strainer was clogged up and I don't mean a bit it was completely blocked ,looked like a sheet of plastic was over the mesh but its done and runs great now
Posted 29 January 2020 - 05:27 pm
Good to hear you got it sorted.
Posted 29 January 2020 - 06:44 pm
Glad you found it. Happy biking.
Excellent long shotting
#16
Posted 29 January 2020 - 07:47 pm
Well diagnosed Sir.
#17
Posted 29 January 2020 - 08:46 pm
good work. so did ya fit the new enjun or fix the old original one?
#18
Posted 29 January 2020 - 09:59 pm
#19
Posted 30 January 2020 - 09:45 am
Got any pics of that, I've never been in there for a look
Hunter S. Thompson.
#20
Posted 30 January 2020 - 10:02 am
this is what i found inside the oil strainer tdm oil starine r.jpg 34.23KB 5 downloads
Also tagged with one or more of these keywords: oil
Start your Engine →
All About TDM →
Oil Lamp Showing Below Taco 900 / 2012Started by peloponezian , 16 Aug 2018 oil, pressure, oil lamp |
Start your Engine →
All About TDM →
Well Oil Be Damned !Started by squonk , 20 Oct 2013 oil |
Start your Engine →
All About TDM →
9Er Using Oil...Started by dmmsta , 08 May 2013 900, oil, consumption |
