Engine Oil Sitting On The Crankcases , Its More Of A Weep Than A Leak
oil leak
21 replies to this topic
#1 gazzztdm
gazzztdm
  • 7 posts
Posted 22 January 2019 - 11:26 pm
Got oil leaking on the gear side of the bike and it sits on the crankcases , cannot work out were it is coming from , any ideas ? Its a 2002 tdm900, Had the tdm going on 4 years and first problem with her , I have put her up for sale and a guy interested wants to know exactly were the oil is coming from , she has been a cracking bike , cheers Gary.
Edited by gazzztdm, 23 January 2019 - 09:13 am.
#2 PICARD
  • 1,744 posts
Posted 23 January 2019 - 07:16 am
Hello and welcome. I'm not an 850 owner so probably can't help, but I'm sure someone who can will be along very shortly.
Meanwhile......why not introduce yourself here......
#3 dablik
  • 10,757 posts
Posted 23 January 2019 - 09:17 am
Hm, bit unusual that, i'm guessing it's the silver 9r in merseyside, does it result in a noticeable oil loss when you check the level ?
#4 thelodger
thelodger
  • 150 posts
Posted 23 January 2019 - 09:23 am
Has someone topped up the oil and spilled it?
#5 gazzztdm
gazzztdm
  • 7 posts
Posted 23 January 2019 - 09:43 am
Yes its the 900 thats p for sale , and a fellow boot-on -the -hill lad lol , its more of a weep than a leak as not enough escapes to even make a drip on the floor , oil level has not changed and it doesnt use much oil so not needed to be topped up , just a bit frustrating working out were its coming from .
Edited by gazzztdm, 23 January 2019 - 10:02 am.
#6 Studley Ramrod
  • 19,215 posts
Posted 23 January 2019 - 10:19 am
Hello gazzzzz.
Many years ago, Ivan had a weep coming from the oil pipe connection.  He cleaned up the oil then covered the area in johnsons baby talcum powder, even though he didn't have a baby, to find out where the oil was coming from.
A photo, or link to a photo would help.
#7 gazzztdm
gazzztdm
  • 7 posts
Posted 23 January 2019 - 10:32 am
Nice one Studley
I will try and see if that works , to be honest i just wanted to sell it with a leak but if i end up working it out i may as well keep her lol , i love the bike , plus there are oil pipes and breathers were it could be coming from , il try and get a photo up :-)
#8 dablik
  • 10,757 posts
Posted 23 January 2019 - 05:24 pm
Agree with Studs, talc's a tried and tested method of finding an oil leak, bit frustrating though eh, hopefully you'll spot it.
#9 gazzztdm
gazzztdm
  • 7 posts
Posted 23 January 2019 - 05:47 pm
Cheers guys , il update you :-)
#10 Gdogg
Gdogg
  • 1,163 posts
Posted 23 January 2019 - 06:39 pm
Also spot on for deducing which is the front and which is the rear of a worm ............ put a worm on a saucer of talc and wait for it to trump the resulting puff of talc will be the give away  :rotflmmfao:
#11 fixitsan
  • 4,676 posts
Posted 23 January 2019 - 06:48 pm
:rotflmmfao: :rotflmmfao: :rotflmmfao: :rotflmmfao:
#12 harvey krumpet
harvey krumpet
  • 2,050 posts
Posted 23 January 2019 - 07:35 pm
Hmmm. I noticed a bit of oil residue om my 8fiddily recently. It was misted over the front of the engine and top of the clutch cover.
The "leak" was one of the small bolts holding the oil filter cover on. Had loosened off slightly.
How the oil ended up away from the bolt is a mystery.
#13 gazzztdm
gazzztdm
  • 7 posts
Posted 23 January 2019 - 08:14 pm
Il give that a check as well , super duper :-)
#14 TKH
Posted 24 January 2019 - 12:45 pm
#15 dapleb
  • 18,118 posts
Posted 24 January 2019 - 01:56 pm
But it mighta sneezed?!
#16 gazzztdm
gazzztdm
  • 7 posts
Posted 24 January 2019 - 05:57 pm
Harvey you got it , A loose bolt on the oil filter cover, talc worked a treat , thanks for all your help , looks like she is here to stay , I think I may treat her to some new oxford heated grips :-).cheers guys .
#17 harvey krumpet
harvey krumpet
  • 2,050 posts
Posted 24 January 2019 - 08:05 pm
Crikey, must be the season for it. Glad it's an easy fix for you.
It's the first time I've had a loose bolt anywhere on the bike. Might replace the o-rings next oil change.
#18 thelodger
thelodger
  • 150 posts
Posted 24 January 2019 - 09:29 pm
For Oxford grips I think you want the Adventure type. It just means the length of the grip is correct for the bike.
BTW be careful not to tighten the oil filter cover bolts too much as they can strip.
#19 TKH
Posted 24 January 2019 - 09:38 pm
Think carefully, the controller thingy on mine has failed after about 12 months what a crock of brown stuff. My plan is to just use an on/off switch. For those in the know electronics wise, should I be putting a resistor or something in to make sure it doesn't overload or similar?
I think I'm cursed with heated grips, this is the 5th I've had fail in 8 years and everyone has failed in a short time.
But yes,agreed, adventure.
Edited by TKH, 24 January 2019 - 09:38 pm.
#20 gazzztdm
gazzztdm
  • 7 posts
Posted 25 January 2019 - 10:26 am
Il have a try with the oxford adventure ones and see how they get on , be interesting to see what set up you end up with using a on/off switch with a resistor .
